Old 11-18-2010, 11:24 PM   #1
PT'S 70 CST
"GO DAWGS"
PT'S 70 CST's Avatar
Interior lights & sunroof problems 2002 Tahoe
I have a odd problem, I put new front and rear door speakers in my wife's 2002 Tahoe and now after I put everything back together I have no interior lights and my sunroof will not move. I have dash lights and my override switch is working because I my outside mirror lights work and I can cut them on and off with the override switch. I cannot turn on my dome lamps at all. I have checked the fuse and even swapped it out just to be sure it was not the problem. The overhead console also has the sunroof control switch in it and the sunroof will not move. Is there a fuse or relay to the sunroof that could be linked to the lights. This is driving me crazy.
PT
70 CST SWB
70 NOVA
93 Indy 500 Pace Truck (SOLD)
94 SILVERADO SWB 5/7 drop
2000 Silverado swb
2005 Nissan Altima 3.5 (Surprisingly very fast)
2004 GMC Yukon XL Denali
BATESBURG, SC. 29006
29006
Some of my restorations
http://www.snapfish.com/snapfish/thu...NAME=snapfish/
Restored Tach tins 8 cyl - 6 cyl
http://67-72chevytrucks.com/vboard/s...d.php?t=518185
Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM
God Bless Our Troops
PT'S 70 CST is offline   Reply With Quote
Old 11-24-2010, 11:40 AM   #2
MattA
MattA's Avatar
Re: Interior lights & sunroof problems 2002 Tahoe
The lamps and roof run off the ctsy fuse in the underhood fuse block. That would be the first place to check.
You could have pinched a wire to one of the door panel lamps when you put the panels back on. The most common place for the circuit to short is at the visor mounts.
MattA is offline   Reply With Quote
Old 11-29-2010, 10:10 AM   #3
PT'S 70 CST
"GO DAWGS"
Thanks, I found it and it was the csty lmp 15 amp fuse under the engine bay.
Thanks PT
70 CST SWB
70 NOVA
2000 Silverado swb
29006
Old 11-29-2010, 10:16 AM   #4
JohnC
JohnC's Avatar
Glad you found it, and it was an easy fix.
JohnC is offline   Reply With Quote
