Old 11-18-2010, 11:33 PM   #1
60apache
60apache's Avatar
5.3 engine mounts
I have a 1960 apache and I am swaping in a 5.3 I have looked at the threads of the different motor mounts but I am unsure which one to use. anybody have any suggestions or comments on which ones I need to get?
60apache is offline   Reply With Quote
Old 11-19-2010, 01:14 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 5.3 engine mounts
This is what I used...
http://www.performanceonline.com/196...LT-IN-ECM6372/
There are also some mounts from ECE that are cool. more $ tho
http://www.earlyclassic.com/catalog.aspx
good luck, you will love the 5.3
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-20-2010, 08:03 PM   #3
60apache
60apache's Avatar
I already have a 350 in the truck so are those what I will need I was thinking that I only need the bracket for the engine.
Old 11-20-2010, 10:50 PM   #4
Ackattack
Ackattack's Avatar
depending on your exhaust manifold/header clearance, what you have for engine stands may work.
I made my own adapter plates to be able to bolt my 5.3L to the SBC motor mounts. There are a few threads about how to do this. Might check the lsx swap info sticky thread above.
Ackattack is offline   Reply With Quote
