11-20-2010, 03:35 AM | #1 |
Salty Sailor
replacing rear main seal in a 2000 silverado, NEED HELP
what is the proper procedure?
drop the transmission and transfer case, then do i need to remove the oil pan too? what else do i need to know for this? thanks
86 c-10 Custom Deluxe Savannah, Georgia |
11-26-2010, 07:28 AM | #2 |
Re: replacing rear main seal in a 2000 silverado, NEED HELP
Are you sure its the rear main? Reason I ask, my daily driver is an '02. I was convinced the rear main was leaking. Turns out it was the oil sending unit. Just unplug wires @ sending unit, if the top of it is wet that may be your problem.
11-27-2010, 08:10 AM | #3 |
oil pan does not have to be removed on these
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Tags |
rear main seal |
