Old 11-20-2010, 04:12 PM   #1
chopttop
Junior Member
chopttop's Avatar
Lowering a C30 motorhome.
Have had a C30 w/motorhome on frame for 4 years now, 350/400. Took it to Sturgis first year, ran well but stopping was a b'itch, would like to use it more. Been reading on swapping crossmembers from newer truck to get disks. Found a donor truck, '80 C30, w/mid 80's , low millage, 454. will remove engine, front suspension, 6 newer michelin tires, newly reduilt 4 speed w/granny gear? and what ever I need and scrap the rest, paid $700.
I have a '71 w/dropped spindles/springs and shocks front and dropped leafs in rear. I would like to do the same to the '70 and should not have a problem w/the '80 suspension, what is the best thing for the rear w/the springs?
Would love to dropmember and bag it, would be the shts to lay frame w/a big old classic motorhome But have to many classics needing different mods.
'71 C10, Choptop/Lowered
'70 C30, w/24' Franklin Motor
'91 9c1 Caprice
'90 Harley FL, 127 Ultima engine w/6 speed, Blk & chrome
chopttop is offline   Reply With Quote
Old 11-20-2010, 06:00 PM   #2
SCOTI
SCOTI's Avatar
Re: Lowering a C30 motorhome.
C30 drop spindles for the front & shackles/hangers or flip kit for the rear. Add some helper air bags to ensure adequate capacity when necessary.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-24-2015, 02:38 PM   #3
stomper
Junior Member
stomper's Avatar
Did you ever get this accomplished? I am exploring doing something with my Winnebago.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Gold White Fleetsides/Saddle
stomper is offline   Reply With Quote
Old 07-24-2015, 05:36 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
When I worked on a 72 Beaver Tail camper, it actually had a modified crossmember from the builder that contained (and this is true) a 215lb ingot of lead held to the crossmember with 3 huge lags. It was designed to balast the overhang of the rear body off the frame.
I'm not sure if you'd run into anything like that, but removing that peice of lead meant the camper was a wheel stander....
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
