11-21-2010, 01:58 AM | #1 |
1983 c10 rearend
What's all. i just installed a 400 tranny behind my 283 small block.
my rear end is holding me back. i want better hywy mileage. Which rearend shoul i install? Thanking all in advance.
Country; LIKE A ROCK All that I am, I owe 62SWB-STEP 83SWB 86LWB |
11-21-2010, 02:06 AM | #2 |
Happy to be here
Re: 1983 c10 rearend
What gear do you have now?
11-21-2010, 02:14 AM | #3 |
If you are so concerned with gas mileage, why did you install a TH400? That is probably the worst transmission, other than a powerglide, as far as gas mileage is concerned. With a 283, you should have been looking for a 700r4 transmission. Better 1st gear ratio for performance plus an overdrive gear for mileage.
- Greg Last edited by 454HO; 11-21-2010 at 02:18 AM. |
11-21-2010, 05:41 AM | #4 |
agreed.
your 283 paired with a 700r4 and running some 3.42 gears would definitely give you some decent gas mileage. (for a truck)
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
11-21-2010, 04:40 PM | #5 |
Also, it would be easier and cheaper to play with rear tire sizes and brands in order to get the right rpm for highway cruising.
Alum wheels and brake drums would also be beneficial. |
11-22-2010, 12:06 AM | #6 |
Thanks for the response. Intially i was running a th-350 (until it died on me). i couldn't afford to rebuild it right now. The th-375 is my stand-by tranny, so i decided to install the th-375. i'm not certain of which gears i have now, i do know it's a posi. I'm currently running a set of 255/60r-15.
Should i change the rear gears to 3:7x or lower and/or install another tranny or keep what i have? Thanking your in advance.
