11-22-2010, 10:22 PM | #1 |
Truck Junkie
Dropped Spindles and Brake Lines??
Anyone else have problems with the stock front rubber lines hitting the tops of the spindles? I can't get them on the calipers. The curved metal tube is hitting the spindles in the ball joint area. 85 C-10 2.5" dropped spindles and 2" dropped springs. Thoughts , ideas?
11-22-2010, 10:25 PM | #2 |
Re: Dropped Spindles and Brake Lines??
install the brake lines on the calipers first. then install calipers and bend the metal fitting on the brake line so that it clears
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
11-22-2010, 10:26 PM | #3 |
67-72 parts collector,…
You have to bend the metal line.
Just tweak it a little. It's very common.
11-22-2010, 10:27 PM | #4 |
but dont over bend it. the older lines can be brittle
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
11-22-2010, 10:36 PM | #5 |
Truck Junkie
My lines are new, the old ones were rotten. How much do you bend them?
11-22-2010, 10:40 PM | #6 |
Just enought to clear.
I usually do it on the caliper, to verify it clears everything.
11-22-2010, 11:20 PM | #7 |
x2. That's how I do them....
11-23-2010, 02:14 PM | #8 |
Truck Junkie
Great thanks guys for all of the input. I'll put the info to good use thanks again
Greg |
11-23-2010, 02:28 PM | #9 |
I use a long HD screwdriver & slowly pry it so that there's 1/8" min clearance around the hose & 90° 'bend' in the line.
11-23-2010, 02:31 PM | #10 |
Truck Junkie
Huh? You bend it down. do you twist it right or left to get it away from the ball joint stud?
