Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-25-2010, 12:30 AM   #1
C-10 simplex
Sooooo........how much power can a 7.5 axle take?
How much power (torque and hp) do you think a 7.5 10 bolt can take?
i'm weighing options and trying to go racing as frugally and expediently as possible. In this case i would leave the engine pretty much stock and concentrate on getting the car as light as possible.
1)at 3500lbs. and slicks?
a) with spool
b) without spool
2) at 3000lbs and slicks?
a) with spool
b) without spool
3) at assuming i can get the car down to 2500lbs. and slicks?
a) with spool
b) without spool
C-10 simplex is offline   Reply With Quote
Old 11-25-2010, 03:32 AM   #2
Bellflower
Re: Sooooo........how much power can a 7.5 axle take?
ive seen some decent numbers w/ 10 bolts, just make sure you get c-clip elimnators, cause when they break, theres nothing to hold the axle and wheel in, seen things get ugly fast that way
Bellflower is offline   Reply With Quote
Old 11-25-2010, 09:29 AM   #3
stich626
a 7.5 axle..
to give u an idea g.m. had to make the gears bigger in the late 80's because the 7.5 could'nt take the tpi 305s wopping 220hp and 325ft lb in the f body..
the 350's got a holden 9 bolt after they gave up try'n to get the 7.6 gear to live..
like anything you can make it live, but you'd be better off finding a 8.5 10 bolt..
if you have the 7.5 now, use it and know it will not take much.. and plan on building a replacement.. c clip isn't really the issue, the axle isn't the weak link..
the gears will die before the axles will. and I'd not spend the money adding house'n ends on a weak 7.5
if you want 12 bolt stong, go find a cheap one,, you might get lucky and find a cheap 12 bolt car rearend.. in your width. but you can find a cheap one.. under every ford made with a v8 . it's called a ford 8.8 a carbon copy of the 12 bolt
good luck
stich626 is offline   Reply With Quote
Old 11-25-2010, 10:45 AM   #4
djracer
djracer's Avatar
If you want it to live find a 9 inch and put a mini spool in it. I would go junkyard hoping till I found what I needed. I ran a stock 28 spline 9 inch and mini spool for years before I upgraded to big axles. This was in my first race car. (67 Camaro)
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 11-25-2010, 12:50 PM   #5
cableguy0
Not much... As stated they didnt hold up in stock applications. They break the ring and pinion A LOT. Any you pull it yard will have a huge selection of rear ends. Grab a ford 9 inch or even an 8.8 out of something as stated. 12 bolts are harder to come by since they havent been in anything since the late 70's.Around here its 65 bucks at the local u pull it yard for a rear.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-30-2010, 01:39 PM   #6
C-10 simplex
1) Which pull it yards have rears for $65? CrazyRay's?
2) In hp and tq numbers how high can i go with a 7.5 10 bolt?
a) 3500 lbs and slicks
ai) without spool
aii) with spool
b) 3000 lbs and slicks
bi) without spool
bii) with spool
c) 2500lbs and slicks
ci) without spool
cii) with spool
P.S. 3) Does using, say, a 4.56 gear as opposed to 2.56, 3.08 etc. allow more power to be transmitted thru the rear thus putting the diff under more stress?
Old 12-03-2010, 02:26 AM   #7
darthwall
I would say if you plan on making power try and get a different rear along the way try and sell you 7.5 before it breaks
darthwall is offline   Reply With Quote
