Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-27-2010, 01:26 PM   #1
Jparks
Jparks's Avatar
Weiand 177
Wondering if anyone has any experience with these? I'm looking at putting a 177 on my built 383 when I get done with the truck build. The engine is around 504 hp/490 tq at the crank. Just wondering what to expect with about 6 lbs of boost. Their website says 25-40% but I don't ever trust those numbers. I know smeding, my engine manufacturer, puts the 6-71 on the 383 if you want to order it that way but I don't really want to cut a hole in my hood. Any thoughts or info would help. Thanks in advance.
72 SWB - Porterbuilt Front/Rear, 22's, 496bbc - "Outkast"
68 Stepside - Porterbuilt Coilover Chassis, 22's, LS3 - "Badfinger"
Jparks is offline   Reply With Quote
Old 11-27-2010, 02:03 PM   #2
cableguy0
Re: Weiand 177
Theres way too many variables to give you a cut and dry answer. 30-40% gain is definately not out of the question with that little baby blower. They work great but what is your compression ratio? What kind of parts do you have in the bottom end? Your bottom end will likely be fine at 500hp but your going to be creeping up on 700hp with that little blower. You start coming into issues of the block holding up crank,rods and pistons as well. 500 and 650-700hp are worlds apart in the sense of the parts needed to make it last. Forced induction is always harder on parts just in itself.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-27-2010, 03:19 PM   #3
Jparks
Jparks's Avatar
Re: Weiand 177
Smeding 383 Extreme Specifications
Block: New GM 4 Bolt Main, Blueprinted in house, Diamond Honed with Torque Plates. 9.025 Deck Height, 1 Piece Rear Main Seal.*
Crankshaft: Forged 4340 Steel with .092 Filet Radius, Micro Polished, Chamfered, 3.800” Stroke.
Rods: High Strength 5140 Forged Steel “I” Beam With ARP WaveLock Rod Bolts, Balanced In Sets.*
Pistons: Hypereutectic 9.8 to 1 with Anti-Friction Graphite Coating to Reduce Friction, Full Floating.*
Rings: Low Friction Single Moly 5/64” x 5/64” x 3/16”*
Camshaft: Custom Ground Hydraulic Roller .510”/.521” lift 231°/236° Duration @.050”, 111° Lobe Centers (Good Vacuum for power brakes.)*
Rocker Arms: 1.5 Ratio, Full Roller with Extra Large Trunions*
Intake: Performer RPM Air Gap, Dual Plane*
Cylinder Heads: Aluminun, 2.02/1.60 Stainless Valves, 67cc Chambers, 170 cc Intake Port Volume for*Great Throttle Response*
Carburetor: Quick Fuel 750 Vacuum Secondary, Dual Feed, Auto Electric Choke, Custom Calibrated on our Dyno
Distributor: High Energy, HEI Polished Aluminum Housing*
Old 11-27-2010, 07:45 PM   #4
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Re: Weiand 177
I would run some forged pistons before i put much boost through it. The Hypereutectic will turn into sand.
That engine combo put up those number?
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 11-27-2010, 08:39 PM   #5
Jparks
Jparks's Avatar
Re: Weiand 177
No it's not that combo exactly, I just pulled that off Smeding's site to give everyone an idea what the motor was like, I didn't have my build sheet in front of me at the time
Old 11-27-2010, 09:22 PM   #6
cableguy0
Re: Weiand 177
The heads stated are tiny. Even for a 350 a 170cc chamber is small. Thats the same size as the stock vortec heads. Flow over .500 lift is going to not be that great. With a 383 generally you dont go any smaller than 180cc and for a performance build usually in the 195-200cc range. At 10-1 compression your really pushing it even with a baby blower. If you want it to live a long and happy life your best bet is to leave it alone.
