Old 11-28-2010, 02:33 AM   #1
dmartin1
dmartin1's Avatar
under carriage clean up/rust?por 15?
ok so ive been coming up on the task of cleaning the entire underside of my truck and i want to spray it with something to protect from the rust and weather etc.
my truck has a good amount of lightsurface rust on everything,and a good amount of baked on hard greese.
now i was thinking about degreasing the entire thing with oven cleaner and a hand wire brush?
am i basically stuck doing the entire under carriage of the truck with a drill and a wire wheel?
how do you guys do it?im not sure i understand yet.
and what should i spray to protect?
ive heard of a few things-rubberized undercoating,cleaning it well and doing it nicely in a few coats of black paint like engine enamel,,or POR-15.
any info on this por 15 stuff would be great! or tips on how you did your truck?
thanks guys!
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 11-28-2010, 04:20 AM   #2
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: under carriage clean up/rust?por 15?
I would borrow a good pressure washer and do it at home. I have not used oven cleaner, but I've used DEP industrial degreaser from Home Depot. The truck I'm working on right now is an ex-farm truck which had its fair share of oil leaks mixed in with heavy dirt...
I also used a pair of wire wheels and good old fashioned elbow grease. It took me 4 days to finally clean the engine and some of the frame, but the complete compartment is not yet done...
I have used Rust Encapsulator from Eastwood and I will use that on the rear frame of my truck. The front is pretty clean so I just sprayed it with Rustoleum.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 11-28-2010, 05:14 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Ditch the POR15
Use ZeroRust.
http://www.zero-rust.com/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 11-28-2010, 01:33 PM   #4
dmartin1
dmartin1's Avatar
that engine bay progress looks good man.
would engine enamel paint be good as i live in arizona with like (-)5 inches of rain a year? lmao
65 nova
And more
Old 11-28-2010, 03:13 PM   #5
TheWhiteElephant
God is good!
That engine enamel is very tough stuff. I've painted several engines with it. The trick (and most important part, as with any paint job) is to start with a very clean, grease-free surface. Once you have it all wire brushed, wipe the surface down with paint thinner or grease remover. I forgot to mention that I also use a Home Depot large spray bottle with a mixture of water and dish washing detergent. That gets rid of the grease very well. You get the idea.
After prepping the area properly, spray the coating on with several light coats, giving each coat ample time to dry. Do this in at least 70 degree weather if you can. The warmer the better. Over the years, I've become pretty handy with the spray can.
By the way, stick with quality spray paint. It makes a huge difference in the final finish. Cheap spray cans have terrible spray nozzles.
Mando
