Old 11-28-2010, 11:41 PM   #1
mcbassin
Still Learning
mcbassin's Avatar
WTB 2-1/2-3" drop spindles, L. control, Rear spring mount Xmember
I am looking for some parts for my 69 project. 2.5-3" Drop spindles if you have extra set? Pass. side lower control arm and rear spring mount cross member. here are some pics of what I need:
Pass side Lower control arm FOUND AT PULL A PART 12-5-10
Still need thisCross member:
mcbassin is offline   Reply With Quote
Old 11-29-2010, 12:26 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: WTB 2-1/2-3" drop spindles, L. control, Rear spring mount Xmember
Mike,... I have a crossmember section on one of my parts trucks (upper shock mounts have been removed),... if you can't find one closer.
I could just sawzall off the frame section.
I can look at it tomorrow,... but I think shipping might kill the deal.
Keith
Convert to disc brakes.
Old 11-29-2010, 12:28 AM   #3
lolife99
lolife99's Avatar
I also have a pair of "rubber bushed" 73-87 lower a-arms,... but shipping would definitely be crazy.
Keith
Old 11-29-2010, 12:47 AM   #4
mcbassin
Still Learning
mcbassin's Avatar
Thanks Keith! take a look at what you have. It might not be too bad to ship snail mail or ups? I know I have some of the cross members out there in my stash, just don't want to cut up a complete frame. I know I don't have any control arms. I only need one, how hard is it to remove the mounting shaft? I bet that there is a bunch of weight in that part.
Old 11-29-2010, 12:52 AM   #5
lolife99
lolife99's Avatar
The a-arms cross shafts are different.
The cross shafts are specific to either 67-72 or 73-87.
I'll try to take a few pics of the crossmember tomorrow.
Keith
Old 11-29-2010, 12:56 AM   #6
mcbassin
Still Learning
mcbassin's Avatar
I am taking this bent one to work tomorrow, maybe I can heat it up and straighten it? Thanks for looking for me.
Old 11-29-2010, 11:55 AM   #7
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I have the lowers and uppers from a 72, if your interested.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-29-2010, 12:23 PM   #8
mcbassin
Still Learning
mcbassin's Avatar
Clyde,
I really only need the passenger side lower. Will you seperate it? how much? Shipping will probably kill the deal for the set.
Old 11-29-2010, 01:23 PM   #9
Clyde65
Clyde65's Avatar
I dont really need them....so whatever you think plus the ride....I dont know if I can do it that way, let me know mods if that is a no no.
Clyde65
Rebuild of Clyde
support our troops!
Old 11-29-2010, 01:44 PM   #10
mcbassin
Still Learning
mcbassin's Avatar
Clyde,
Just price the one lower side plus shipping to me. I don't think there is any issue with you giving it to me cheap or free. Since you are not soliciting a buyer it should be okay. I really don't want to price another mans part.
You don't happen to know if 71-72 are part specific? I have a few other half ton control arms, just curious if any of them would work?
Old 11-29-2010, 04:07 PM   #11
Clyde65
Clyde65's Avatar
I bought some from a 68 and cleaned them up and powder coated them, installed the new shafts and ball joints then installed, no difference from the 65 to the 72 to the 72 that I could tell other than the mounts for the sway bar wasnt on the 68's and was on the 72.
I believe they are all the same from 63-72, with the exception of the 71-72 have the sway bar mounts. ( I think that is correct)
Clyde65
Rebuild of Clyde
support our troops!
Old 11-29-2010, 07:55 PM   #12
lolife99
lolife99's Avatar
Mike here's a couple pics.
If you need different angles,... I'll have to get them tomorrow.
(it get's dark too early now)
I really think shipping will kill this deal.
How about $20.00 plus shipping.
My zip code is 65251.
I use UPS, since they are here in town.
Do you have any idea what this thing weighs?
I hate to estimate shipping,... but I don't want to cut it off if you don't want it.
It's holding the rear of the truck up off the ground. Ha.
I was just going to cut directly in front of the crossmember.
Keith
Old 11-30-2010, 12:50 AM   #13
mcbassin
Still Learning
mcbassin's Avatar
Defintelythe part I need. Like you said shipping might kill the deal. I am going to pull the old one out and weigh it. I will be in touch. Thanks for your help!
ps. you ever get to use any spacers?
Old 11-30-2010, 07:38 AM   #14
lolife99
lolife99's Avatar
No,... I still have the spacers but no Coys wheels yet.
What exactly is wrong with your crossmember?
I may need to look real close at mine and make sure it's not rusted or anything else.
Keith
Old 11-30-2010, 09:38 AM   #15
mcbassin
Still Learning
mcbassin's Avatar
If you look at the pic on the top you can see where it was welded. Basically it has had several cracks fixed on it. not sure what the problem was, bad shocks?
Old 11-30-2010, 09:44 AM   #16
lolife99
lolife99's Avatar
Do you need a set of stock upper shock mounts?
(I might still have a set)
Or are you going to use a set of rear shock relocators?
Keith
Old 11-30-2010, 12:35 PM   #17
mcbassin
Still Learning
mcbassin's Avatar
You tell me, I was thinking of making it about 4-5 in. lower in the rear and 3 in the front with spindles and shocks. Not really sure what it takes to make a static drop in the rear. I don't want to c-notch or anything drastic. I still want to use it for pickup duties. If I can leave the shocks where they were from the factory then I will need those too.
Also, I just found out through some research that it looks like the rh control arm I'm looking for is the same on the square bodies. So I should be able to pick one up at pull a part pretty cheap.
Old 11-30-2010, 12:52 PM   #18
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
With that much rear drop you'll definitely want to run rear shock relocators.
As far as the lower A-arm, I'm not sure, Keith is the right guy to be asking. Wish I could help you out more.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 11-30-2010, 01:15 PM   #19
lolife99
lolife99's Avatar
I would use the rear shock relocators with anything more than a 3" drop.
ECE, POL, CPP all sell them.
You can run up to a 6" rear drop coil without a c-notch.
Nate (72BlckButy) has a 6" rear drop with no c-notch,... and it's fine.
Keith
Old 11-30-2010, 01:16 PM   #20
lolife99
lolife99's Avatar
Yes,... the 73-87 (squarebody) a-arms will bolt right on.
The lower ball joint will have to match the year spindle you are using.
(63-70, 71-87)
Keith
Old 12-12-2010, 03:14 AM   #21
mcbassin
Still Learning
mcbassin's Avatar
(63-70, 71-87)
Keith,
Thanks for the info on Nate's truck, I really like the height on it too.
Still haven't had time to remove the old cross member yet. I really think I need to find it local because of the weight.
Old 12-12-2010, 09:38 AM   #22
greg65
greg65's Avatar
I just bought the same crossmember for my son's 69 project. The weight on the box was 24 lbs. and shipping from Florence S.C. to right out side of Atlanta Ga. was $25.00. Hope this helps.
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 12-13-2010, 12:01 AM   #23
mcbassin
Still Learning
mcbassin's Avatar
Thanks for the info Greg65. I was able to pull the cross member today and weigh it. It weighs right at 15lbs with the frame piece it will be closer to 25lb. Keith, can you see how much it would cost to ship it from your place to 74851 OK? Thanks.
Old 12-13-2010, 12:03 AM   #24
mcbassin
Still Learning
mcbassin's Avatar
Here is what it looked like on the under side. Trashed!
Old 12-13-2010, 05:40 AM   #25
lolife99
lolife99's Avatar
I use UPS.
It might be a few days before I can get to it.
It's 4* here and it's covered in snow.
You will need to add the length (and weight) of the two frame rail sections also.
Keith
