1987 k5
Good evening, i'm usually over on the 67-72 side, but we bought a 87 k5 with 49k on it came from the carolina's.
Its got an oil cooler, a GU6 and a g80 posi so i'm guessing tow package? The decal on the rad support reads 5.7, the SPID reads LO5 which is a car engine. I can't decode the vin, i have used Compnine, and i've done a search here also. Vin reads 1GNEV18K5F****** And the vin is the same on the dash, SPID label, and a tag that says "this vehicle should not be equipped with a slide in camper". Though that would be a neat site. Any help would be great, i'm lost on what we really have. We got taken a little i think. The bodies in great shape, but i think someone changed the tag, and its had some work done. Thanks Glen
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. Last edited by no moa; 12-01-2010 at 05:33 PM. |
Re: 1987 k5
http://service.gm.com/dealerworld/vi.../vincard87.pdf
1 = made in usa G = GM N = ??? should be C E = GVWR Brake System rated 6001 - 7000 lbs V = Conventional Cab 4X4 1 = 1/2 ton 8 = Blazer K = 5.7 v8 5 = check digit F = 1985 model year which doesn't fit the rest of the VIN plate If its a 1985 then the VIN decodes as 1 = made in usa G = GM N = ??? should be C E = GVWR Brake System rated 6001 - 7000 lbs V = ??? should be K for 4X4 C for 4X2 1 = 1/2 ton 8 = Blazer K = 5.7 v8 5 = check digit F = 1985 model year http://service.gm.com/dealerworld/vi.../vincard85.pdf hope this helps Last edited by tobiahr; 12-02-2010 at 08:44 AM. |
Re: 1987 k5
The decal shows 11/86 in the door tag. But then that first mean much, doors could have been swapped. But I dont know.
I don't know what the n is. Can't be a misprint on all 3 decals. More searching I guess. Thanks for the info. Glen Posted via Mobile Device
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
#4 | ||
Re: 1987 k5
Hmmm - everything almost makes sense....
Actually -no. The L05 is the 5.7l 350 cu in engine used; there also was a L03 5.0l 305 cu in engine in that same time frame (not available in V Blazer, IIRC). Quote:
That "F" , however, for the model year doesn't make sense - Quote:
And - no problems regarding the "slide in camper" note. That was a generic note added to removable top utilities, so it does not indicate any tomfoolery. Summary: to me everything adds up except that model year indicator. MHO - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 12-02-2010 at 10:43 AM. |
Re: 1987 k5
Lo3 that's right, thank you for that, its been awhile dealing with the "newer" stuff! Lol.
I'll check the vin again. The N confused me, but now that we have that straight I'll Check the vin again for the last digits. Thank you Glen Posted via Mobile Device UPDATE it is "HF"
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. Last edited by no moa; 12-02-2010 at 11:18 AM. Reason: Update |
Re: 1987 k5
Excellent! Then you are all set (everything makes sense to me) -
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
