I have no clue why this is happening..
Re: Water getting into my cab and rusting floor!
mine leaks water on the floor too...I know it's a problem with these trucks. prob a hole rusted some where.
your cowl is rusted out. i have the same problem. if you pull the cowl filler piece off and look down in ther you will see that its rusted out. you can buy the replacement pannel to fix it i believe lmc offers them. its a pretty common problem.
Lindsey Rae 85' chevy long box, built by a girl! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=429956 |
6.0 powered square
mine leaked like crazy so I closed the cowl up on the cab with HVAC aluminum tape no more puddles
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
Whoa, I don't know how to take it off. and I also Don't know how to get down in there. And do you suppose JB Weld ?
bump.
Chris
lmc has cowls now? I didn't know that. I know they got the screens and ones with bolts or clips, and then the lower cowls which is the lower firewall on the outside.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
Live fast, die young
Do you have cab lights? That was the source of my leak. Some silicone around the base(s) and around the cracks and that ended it.
#9 | |
Getcha Pull
To get the cowl piece off you pull the wind shield wipers, and you'll find a few bolts holding the cowl on. After that is a plastic vent piece which also unbolts. Then you'll be able to see down in there. Clean out any gunk, and look for rust. Even if it turns out that isn't the problem, it doesn't hurt to clean it. Would have kept mine from having a new vent for the engine...
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
wow thanks guys! I got it sealed up with some Jb weld!
#12 | |
#13 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Wrote this tech article for just this situation.
http://forum.73-87chevytrucks.com/sm...?topic=12521.0
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
