Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-02-2010, 01:13 PM   #1
bravo
bravo's Avatar
How much Nitrous
I have a 496 motor and was curious how much i can spray.
standard 454 4-bolt main
4340 eagle crank
4340 h-beam rods
srp forged pistons
brodix bb-2 plus heads
solid roller cam
1050 dominator
brodix single plane intake
the most i have ever sprayed was 250 shot. My question is can I spray more without hurting the motor. Thanks for any input.
bravo is offline   Reply With Quote
Old 12-02-2010, 02:57 PM   #2
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: How much Nitrous
What kind of rings and what are they gapped at? If you've got the right rings and know how to tune nitrous the right way then your motor will handle plenty more.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 12-02-2010, 03:03 PM   #3
bravo
bravo's Avatar
All I know about the rings is that they are for nitrous. The machine shop ordered them for me.
Old 12-02-2010, 03:45 PM   #4
swb85
swb85's Avatar
I would find out what the rings are gapped to if you don't know, as that will be a big factor in how much gas it can handle. If the gaps are wide enough, I wouldn't be hesitant to hit a nicely built 496 like yours with 400hp through a fogger (again, with a good tune). I'd probably start at 175-200 and clean the tune up, then slowly move up from there.
Old 12-03-2010, 01:03 AM   #5
ripdog28
ripdog28's Avatar
If N2O rings, i would say about 4-500. Those pistons are no joke.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 12-03-2010, 02:20 AM   #6
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
There is many guys at the local track with a lot less motor than you have spraying 2 to 3 systems to get them into the 8's. You should be able to hit 300-400 easy.
It's all in the tune like swb85 said. 1st I would make sure the motor is on a correct tune by reading your plugs on the 1st pass and tune from there on the motor. If the motor is rich the N2o system will be also. You could bang the engine and wound it.
Your also going to need to pull proper timing out per tune up.
There is a point in were the motor just cant burn all the fuel because the spark is not hot enough and you will blow the fame out. So make sure your plug gap is closed up and run a cut back ground strap. (Champion 295) or =
I would also contact your N2o systems rep. Talk to them about your combo and how much you want to put on it. They Should give you a jet set up to run, (35-31 example) a fuel psi LOW or HIGH. I'm kinda partial to high pressure tunes. You will need a flow set up that reads is 10ths or 8ths of a pound of psi. to flow at the given jet size for your tune.
Bottle heat = bottle psi. This has to be consistent every time or it changes the characteristics of the tune.
Go out and run it down Broadway with a grin ear to ear!
Just my 2 cents. not saying I'm right.
I personally would like to see some research on running a mag on a n20 system.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 12-03-2010, 10:59 AM   #7
bravo
bravo's Avatar
Thanks alot for all the info!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
