grease electric window mechanism without removing doorpanel
temperatures are down to freesing at the moment en the electric windows of our burb are giving us a hard time. very slow and sometimes not fully opening or closing.
I opened up one doorpanel recently and saw that the mechanism is as dry as a dessert-rats-ass... Is there a way of greasing this mechanism without having to open the doorpanel, because that is way too cold right now and I have no place to do that inside. hope you guys can help me!
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
Re: grease electric window mechanism without removing doorpanel
I don't know of any way. Removing the door panel doesn't take very long, as you know, but I understand the problem with cold weather. However, I would not necessarily think that grease alone will solve your problem - could be cold weather affecting the performance of your motor(s).
#3 | |
probably motorproblems too, but I wanna make sure its greased properly to take that out of the way....
#4 | |
You could always get to it from the outside, an air-chisel will peel that sheetmetal right out of the way....
![]() No, really the only way is to remove the door panel. Just be sure to use something that can deal with the cold. A synthetic lube that will not turn sticky and stiff when it is freezing would be best. There is no point in going from "dry" to "glued"
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
78K & 79C Jimmys
had to replace the fuel tank,and it was real cold
threw big tarp,covered ground to ground on sides hung over the gate ,put heater inside truck pointing at me and a rope around the belly,boards up the sides also make sure the window and tracks are lined up straight well greasin things make sure to do the hinge for the door with out they sieze/stiffen up,seen them bend
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 12-03-2010 at 07:58 AM. |
If you can get your hands on some grease rated for artic conditions that would be the was to go. When I lived in Fairbanks, AK that was the type of grease I used, it doesn't harden up under extream cold conditions. Used it on the windows and everywhere else you need to grease, mostly the wheel bearings.
#7 | |
