12-12-2010, 11:49 AM | #1 |
pics of bed covered trucks....
can you guys post some pics of your trucks with bed covers.
thinking that id like to put one on to protect the bed and give me some time before i get to working on the bed itself. gotta sand or sandblast or something. getting cold here in jersey, so figure i can protect bed with a cover. any pics and info on where i can pick one up for a decent dollar would help. thanks j |
12-14-2010, 01:22 PM | #2 |
Re: pics of bed covered trucks....
0??
12-14-2010, 01:26 PM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
is this what your looking for?
1964 C20 Crew Cab Longbed, it has a Gaylords bed cover, hard cover.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 12-14-2010 at 01:27 PM. |
12-14-2010, 01:27 PM | #4 |
that is exactly what I am looking for!!
12-14-2010, 01:28 PM | #5 |
id would rather a soft top look. not so much the hard top
12-14-2010, 10:26 PM | #6 |
The One And Only !!!
Put a Extang on my 97 two and a half years ago, Use nothing but their Tonno Tonic on it and it still looks like new.
This place had the best price I could find at the time; http://www.truckchamp.com/tonneau-co...ng/series/tuff Will likely put the same on my 74, IMO.....Snaps down the side scream cheap !
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
12-14-2010, 11:05 PM | #7 |
its an old cover but it does the trick
12-14-2010, 11:19 PM | #8 |
We mounted angle iron along the bed rails, the two sides and the back of the bed. Built a frame out of pressure treated 1x2's. Went to a local sign shop and got some aluminite(two pieces of aluminum sandwitching corregated plastic, very light) scraps, in other words signs they had discontinued or was no longer able to use. Come in 4x8 sheets 3/8's inch thick. $20 for two sheets. Screwed it down to the frame, added a sheet of plywood underneath for strength and mounted it on the bed it's not done Plan on covering it
12-14-2010, 11:51 PM | #9 |
.. !WAR FEDOR! ..
just a cheapy summit one, but its looks better than the plastic cut up bedliner that i had in before..
"san diego chargers #1" |
12-15-2010, 09:56 AM | #10 |
Here you go it is a Black Max cover but soon to be a Gaylords fiberglass hard cover.
"WIDER IS BETTER" (TRUCKS ONLY) |
