Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 12-12-2010, 06:38 PM   #1
chevyndn
4x4 to 2 wheel drive
does anyone know what would need to be done in order to convert a 4x4 97 blzer into a 2 wheel drive? im not to worried about a motor or trans, the only thing im worried about is the front diff. what would i have to do to convert all of it?
chevyndn is offline   Reply With Quote
Old 12-12-2010, 07:17 PM   #2
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
Re: 4x4 to 2 wheel drive
I'm not positive but I'd think the whole xmember with a-arms and the steering components. all that. might need a diff steering gear box too. BUT this is kinda a guess
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 12-13-2010, 11:37 AM   #3
BarryB
BarryB's Avatar
I'm 90% sure the frames are different. I remember checking into making a 2wd a 4wd and that is what stopped me. If it was me and I had to did it. I would find another frame to swap my body over on, or just find a 2wd blazer.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 12-14-2010, 12:50 PM   #4
Tink
Tink's Avatar
You could convert 4wd to a 2wd the way GM did it... (like the 2500HD 2wd trucks) leave the 4wd suspension... just remove everything and then disassemble the CV axles to put the splined ends through the hub assembly.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 12-14-2010, 07:10 PM   #5
95 S_Trucker
95 S_Trucker's Avatar
thats the best way to do it. and if you ever decide to do a v8 swap, it will make it very easy. you can run whatever oil pan you want too, unlike the factory 2wd
95 S_Trucker is offline   Reply With Quote
Old 12-15-2010, 11:04 PM   #6
chevyndn
well im undecided if i want it a 2 wheel drive with a v8 or if i should leave it 4x4 and do a v8 swap
Old 12-15-2010, 11:11 PM   #7
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
do a v8 swap and an awd swap. Use the xfer case from an awd astro or bravada and make a syclone/typhoon style truck. I researched it a while back and they used the 4wd frames for them i think.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 12-15-2010, 11:12 PM   #8
chevyndn
here let me set it up for yall. i bought this car feb. this year. i didnt check it out all the way when i bought it cause it was only 450 bucks. at first i thought it need just a hub and an axle,upon further inspection i found out it needs the front diff replaced, but i dont know if i wanna do that or say screw it and make it 2 wheel drive. i wanna put a v8 in it, but im kinda wanna leave it v6 for my dd....im just having a hard time findin a pair of diffs that match. the owner before me also swaped out the rear for an 01 blazer rear for the disk on the back and im not sure of the ratio cause im having trouble findin the numbers.
Old 12-19-2010, 06:22 PM   #9
66redw/white
made in america
66redw/white's Avatar
i wouldnt say that leavin it v6 would make it more daily driver friendly. the 4.3 v6s dont get very good gas mileage at all. my 02 slammed 2wd got at best 16mpg around town. and 18 mpg on the highway. my gmc sierra with a 5.3 gets better than that. i did just buy myself a 4x4 jimmy. its a 1990. my plan is strictly aimed at performance. but i plan to do a 5.3l bored and stroked to 383, a 4l80e, awd transfercase and front axle from the astro van they were talking about above, and possibly a small turbo. really it all comes down to what your gonna do with it. i want to haul the mail and launch outta the whole like theres no tommorrow. what are you wanting to achieve?
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes.
sounds good
1964 c10-283 powerpack, 3 on the tree
2004 corvette- lowered, borla, tuned. slow
my old girl
1966 c10- 305v8, t-5 sold
66redw/white is offline   Reply With Quote
Old 12-19-2010, 07:49 PM   #10
chevyndn
thinks for all the input everyone!!!! it is very helpful!!! i think i kinda wanna do a typhoon project.... i have one more question..... would it be better to keep if fuel injected or carb wit a v8? the blazer as it sit has a 5 speed tranny in it.... im not sure if the computer is hooked up to it or not...
Old 12-19-2010, 08:09 PM   #11
66redw/white
made in america
things usually change for the better. so id say fuel injection would be the better way to go. keeping the 5 speed may present a problem. they arent rated for very much torque. with a 2wd that had skinny tires id say keep it because you will spin the tires before you break the tranny. but if you want to do the awd thing then that 5 speed with a v8 infront of it..... well i dont see it lasting that long.
sounds good
my old girl
Old 12-19-2010, 08:15 PM   #12
chevyndn
yeah thats a good point, i do have a heavy right foot to top it off....
