Old 12-15-2010, 10:06 PM   #1
jojoman
is it too low
was just wondering if a 5/6 5/7 drop would be to much for 15 inch wheels cuz i want to put 20's but don't want to ride them every day
jojoman is offline   Reply With Quote
Old 12-15-2010, 10:16 PM   #2
Jonboy
Slots go on anything!
Re: is it too low
I don't think so. My truck is about 6/8, and it is on rally wheels. My slots will be 15's, too.
1974 Jimmy- 5.3/4L80e/NP241
Old 12-15-2010, 10:17 PM   #3
scooterskoolkustoms
scooterskoolkustoms's Avatar
Re: is it too low
I have a 5/7 now on my burb with 15 and it is fine.
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline   Reply With Quote
Old 12-15-2010, 10:20 PM   #4
muthstryker
muthstryker's Avatar
Re: is it too low
I have a 6/8, My front tire when I had my 20s was 26"s tall. It was fine, it was low and I had to remove my inner fenders but no major problems. If you just make sure your 15s have a 26" or taller tire ( I wouldnt go over 27-28"s) you will be fine.
muthstryker is offline   Reply With Quote
Old 12-15-2010, 10:50 PM   #5
mooseknuckles
mooseknuckles's Avatar
Re: is it too low
5/7 should be ok, front tires may rub on inner fenders, but you can always take them out. you will have to anyway if you want to go lower.....and you will.
mooseknuckles is offline   Reply With Quote
Old 12-15-2010, 10:55 PM   #6
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: is it too low
have over a 5-7 and its just right with 15s
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 12-15-2010, 11:07 PM   #7
jojoman
Re: is it too low
koo man i really thank all of ya for helping me out cuz i bought this truck but the guy really messed the suspension up and i really dont know where to start cuz i dont even know what drop it has right now so yea i thank all you guys this is the truck and the leafs should i get flip kit i like how it sit just dont like all the bouncing around and is a lil higher in front but he already cut springs alot
Old 12-15-2010, 11:25 PM   #8
mooseknuckles
Re: is it too low
I think it's fine for now, you don't really need the back any lower, the front looks like it should come down, the spindles should fix that. mine was the same way...definately cut that bump stop out of the back tho and it should ride better unless the shocks are done?
Old 12-15-2010, 11:49 PM   #9
jojoman
Re: is it too low
thank again ya i will remove the bump stops for now and new drop shocks and see how it rides and will let you guys know
