12-16-2010, 01:32 PM | #1 |
Yeah baby!
Slick Balancing?
Do you get your drag slicks balanced?
11.37 @116 |
12-16-2010, 02:18 PM | #2 |
Re: Slick Balancing?
Yes.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
12-16-2010, 03:00 PM | #3 |
On a budget like Fred Sanford
+1 for balancing
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
12-16-2010, 05:33 PM | #4 |
Where and how?
12-16-2010, 05:42 PM | #5 |
make sure the weights cant come off
12-16-2010, 09:59 PM | #6 |
Mean Green
Yes I also get my slicks balanced.
They can not use out side weights. They have to use tape weights. Then you have to tape them down with a duct tape grade or better. Just think of it as out of balanced rotating mass. Think of the carnage it would do if that was your crank.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. |
12-16-2010, 10:06 PM | #7 |
for sure
12-17-2010, 01:22 AM | #8 |
My Carbon Footprint
I worked for a tire shop back from '82-'91. Not sure how the balancers have changed in those years but it's tricky if you have a DEEP polished lip and don't want tape weights on the outside of your wheels. Most balancers, at least back then, split the wheel down the middle and gave you a weight for each side making it hard to tape to just the inside. If you find someone or a shop that knows what they are doing, they make glue on weights that are just like a repair patch for fixing a flat. Usually used for balancing semi tires but you can cut them down and actually buff/glue them to the inside of the tire requiring far less weight to balance because it is so far to the outside like the heavy spot in the tire! Just a thought.
12-17-2010, 11:36 AM | #9 |
Registered Truck Offender
The tape on weights and then cover them with a piece of aluminum duct tape is what I usually do. BUT if you have disks make sure you know where the disks run in the wheel so the weights don't hit. A 15" wheel with a 3+" backspace gets REAL CLOSE to the Willwood / Aerospace calipers.
I have to find a shop that is willing to slip a magnet in the hood sensor to bypass the hood safety when your using big pfhat wide tires. Most hoods and computer balancers wont accept anything over a 11 or 12" slick.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
12-17-2010, 03:03 PM | #10 |
I've had good luck, dismounting the tire and moving it on the rim.
most times you can get it real close this way u only need small weights.. |
12-17-2010, 04:41 PM | #11 |
Boosted Member
They're not "Drag Slicks" but I do balance my M/T ET Street radials...no reason not to. Makes driving to work on them a little nicer
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
12-18-2010, 01:50 AM | #12 |
At the body shop.
Guess i need screws then, my hoosier D/R's turn on the wheel. Then shakes like... well you know. I peeled off the weights.
12-18-2010, 11:48 AM | #13 | |
Mean Green
I used my window chalk to mark my tire and wheel.
12-24-2010, 04:22 AM | #14 |
Does doing burnouts throw the slicks off balance? Just wondering. I didn't get my slicks balanced this time because I didn't trust any of the shops around here(100+ miles from the nearest big city). So far I haven't had shaking or vibrating problems.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
12-24-2010, 11:19 AM | #15 | |
the slicks i ran on my old mustang were balanced then duct taped over. never had a problem with the tire spinnin on the rim though. did the same thing and marked the valvestem location on rim/tire to check for play and never had anything move. |
