Old 12-26-2010, 10:18 AM   #1
72ArizonaBurb
Suburban Drive Shaft Same as Long Bed Truck?
Someone put a 1 piece drive shaft in my 72 Suburban. I am returning it to stock and need to change out the drive shaft. Will a drive shaft (2 piece) from a LWB truck work? If not does anyone know if there is a later model truck drive shaft that will fit that I can get from a junk yard?
Thanks,
Keith
72ArizonaBurb is offline   Reply With Quote
Old 12-26-2010, 10:22 AM   #2
cpetersen
cpetersen's Avatar
Re: Suburban Drive Shaft Same as Long Bed Truck?
Should be the same. Just try to get the carrier bearing set up the same. Did the leave the carrier bearing bracket there?
cpetersen is offline   Reply With Quote
Old 12-26-2010, 02:48 PM   #3
72ArizonaBurb
I haven't looked to see about the carrier bracket. I am getting 72 Super Cheyenne parts truck and it should have everything I need. I will put new U-joints in and buy a new carrier bearing. Hopefull I will be good to go. Thanks for the info.
Old 12-26-2010, 03:46 PM   #4
cpetersen
cpetersen's Avatar
The 72's have the good u shaped carriers> You should put all new parts in there are no problems that way. Good luck. Did your parts truck come with a BBC? My 72 did and had big drive shafts in it< my 68 had skinny shafts, it came with a 327.
Old 12-26-2010, 09:15 PM   #5
1956cameo
1956cameo's Avatar
It should work. I took a drive shaft out of a 72' suburban and successfully put it into a 70' longbed truck.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 12-27-2010, 10:00 AM   #6
72ArizonaBurb
Thanks. This is good to know. Now I can move on start figuring what I need do next.
