Old 01-11-2011, 10:24 AM   #1
JimQ
JimQ's Avatar
'64 K20 4x4 Clunk - What is it?
Hey All,
Relatively new to the forum and classic Chevy trucks.
I picked up a '64 K20 this summer. I've been working on bringing it back to a driver.
We finally got some snow here in S.E. Nebraska and I got a chance to use it drive it in 4wd
When in 4wd, the truck "clunks" and jerks a bit. Maybe once every 5 or 10 seconds. Definitely does it more when accelerating.
I know, not much info here.
I guess what I'm wondering is, could this a transfer case issue? Are these cases known to do this? Or is it more likely a knuckle joint binding?
Any thoughts?
Thanks,
Q
'64 K20 327
JimQ is offline   Reply With Quote
Old 01-11-2011, 02:34 PM   #2
csb#356
Re: '64 K20 4x4 Clunk - What is it?
I don't have any experience with those rockwells but I had a 74 with a 203 case and it made the same kind of noise but it sounded like it was coming from the axle, still changed out the 203 for the original 205 and problem fixed. Maybe you could put the front up on jack stands, disconnect the rear drive shaft and then run it in 4wd, and see if you can get a better idea.
csb#356 is offline   Reply With Quote
Old 01-15-2011, 07:55 PM   #3
ND_guy
Tool Addiction=Money Shortage
ND_guy's Avatar
I had the same when i was accelerating after I lifted the pickup. The pickup drove fine until hitting a bump or the front suspension extended causing a sharp clunk. After investigating if found the front driveshaft binding at the t-case yoke. The two halves of the joint were contacting each other because the angle was too extreme. To temporarily fix it I ground the yoke for clearance. That temporary fix has lasted two years
1967 K20 400TBI SM465/NP205
posi front, Detroit locker 4.56 rear
ND_guy is offline   Reply With Quote
Old 01-16-2011, 10:12 AM   #4
eric67m
eric67m's Avatar
Are the gear ratios the same in the front and rear axles?
eric67m is offline   Reply With Quote
Old 01-17-2011, 11:17 AM   #5
JimQ
JimQ's Avatar
Good question. I assume they are but I haven't checked the tags to make sure. The truck is relatively new to me.
Thanks,
Q
'64 K20 327
Old 01-23-2011, 01:44 PM   #6
rayfinseats
Remove the covers and actuallly look at the ring gears. They will have a number such as 41 11. 41 divided by 11 = gear ratio. The other thing is it could be missing a tooth on the ring gear or maybe transfer case. Start with the rearend covers...
rayfinseats is offline   Reply With Quote
Old 01-23-2011, 03:54 PM   #7
chas350
check the wheel joints
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 01-24-2011, 10:29 AM   #8
JimQ
JimQ's Avatar
Is there an easy way to do that with closed knuckle?
Do I just lock in the hubs, put it in 4wd and in gear, lift the front end, rotate the wheel and check for play? Or is there another way?
Thanks,
Q
'64 K20 327
Old 01-24-2011, 02:44 PM   #9
chas350
sounds like as good an idea as any good luck, sorry no experience with a closed knuckle
quote by LEEVON
70 K20 long fleet
98 G3500 work van
Old 01-24-2011, 11:29 PM   #10
'63GENIII
'63GENIII's Avatar
My '63 is pretty jerky and makes alot of noise also. My gears are 4:10 and 4:11 front to rear or vice versa. It did it with the closed knuckle axle that was in it originally too and I guessed that it was normal. At this point, I've run my new axles for a few hundred in four hi and even though it makes noise (especially that damn T221!) it has yet to fail or act like it's getting worse. Sorry for I too have no advice for the closed knucks. It was easier to swap to the 44 hd (open knucks) for me.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 01-25-2011, 10:36 AM   #11
JimQ
JimQ's Avatar
So when you mention noise from the T221 do you mean gear whine or do you mean a sharp clunk/bind noise?
Is there anyone else that would say this might be "normal".
Thanks.
Q
'64 K20 327
Old 01-26-2011, 12:29 AM   #12
'63GENIII
'63GENIII's Avatar
Definitely talking about gear whine which is normal due to the straight cut gears. The clunking and binding is more of a front end "feature". I would not say that clunking from the t case is normal though.
Chris
'63 k15 long step
