Old 01-14-2011, 12:16 AM   #1
rollin thunder
rollin thunder's Avatar
help with diagnosing a knock in my engine
I have a 1984 Chevrolet 1/2 ton c 10 with a 250cu straight six.This is an amazing find i got it for only a $100 and for the shape its crazy i have only read about these finds but the only thing i noticed wrong with it is it has a knock in the engine. It sounds like it is coming from deep like almost the bottom of the block. I thought it might be a wrist pin and i tried pulling spark plugs caps on each cylinder at a time and that had no effect on the knock. Any suggestions? or maybe it is a wrist pin and isn't the piston still moving so maybe the knock would continue? makes sense i guess i am still learning so any advice would be great
rollin thunder is offline   Reply With Quote
Old 01-14-2011, 01:00 AM   #2
Willys47
Willys47's Avatar
Re: help with diagnosing a knock in my engine
do you have oil presure?
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 01-15-2011, 12:51 AM   #3
rollin thunder
yeah I have oil pressure
Old 02-13-2011, 07:16 PM   #4
rollin thunder
[IMG]100000046668860&aid=28782#!/photo.php?fbid=150207834990771&set=a.150203861657835.28782.100000046668860&theater[/IMG]
Old 02-13-2011, 08:38 PM   #5
463
463's Avatar
we had a 250 with bad piston slap sounded like a deisel motor. ran a lot of miles like that.
Trueman
463 is offline   Reply With Quote
Old 02-13-2011, 10:54 PM   #6
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Flexplate?
ETsC10 is offline   Reply With Quote
Old 02-16-2011, 07:21 PM   #7
rollin thunder
as far as it being a flexplate i forgot to mention (manual, 3 speed on column) i just recently replaced the entire clutch assembly flywheel included i figured since i was taking the transmission down i might as well check everything else out and replace it. but i am going to pull the motor and have it completely rebuilt at a performance shop locally so i can wait till then to find out what it is exactly and if it is just a piston slap which i got more information from some of the shops and they all agree its probably that then im good to drive it till i pull the motor i assume. Can not wait till the truck is finished i have a lot of plans for it i will try and get some pics on this thread soon of then and now
Old 02-17-2011, 04:06 PM   #8
rollin thunder
the day we brought it home
[IMG][/IMG]
the same day after we washed and waxed and replaced all fluids
Old 02-17-2011, 04:10 PM   #9
rollin thunder
[IMG][/IMG]
About a month later here... and i`m gonna go take pics of it today here in a little bit
84 truck, chevy c10, engine knock, straight six
