Old 01-19-2011, 04:37 PM   #1
hsdropout
Brake Line Tubing Size?
I need to run my brake lines now. I am planning on matching the rear lines to what was existing, 3/16" to new MC with proportioning valve. My question is can I run 3/16" lines to the new front disc brakes from proportioning valve?
I read where possibly it should be 1/4" to new discs.
Anybody have first hand experience with this. Thanks.
hsdropout is offline   Reply With Quote
Old 01-19-2011, 05:47 PM   #2
Kim57
Kim57's Avatar
Re: Brake Line Tubing Size?
I ran 3/16 line for all mine and I'm running 4 wheel discs. Not on the road yet but I have no worries about doing it this way.
Kim
Kim57 is offline   Reply With Quote
Old 01-19-2011, 07:22 PM   #3
RootBeer 6117
RootBeer 6117's Avatar
At school we recently fixed a 98 dodge cummins 2500 ext cab that had 3/16 line all the way to the back with rear disc, my 95 k1500 ext cab has 1/4 to the rear drum and 3/16 up front.Their might be some that argue size matters but if a 3/16 line will work on a 2500 cummins dodge I would think it would be fine on a AD truck.
I did a lot of disc brake swaps on 60's Chevy truck and used 3/16 on the front and 1/4 rear.
Joe
RootBeer 6117 is offline   Reply With Quote
Old 01-19-2011, 09:34 PM   #4
whid
I did 3/16 to front disc..1/4 to the rear hose tee then 3/16 out to the drums......whid
whid is offline   Reply With Quote
Old 01-19-2011, 10:57 PM   #5
solidaxel
solidaxel's Avatar
Me too!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-20-2011, 12:22 AM   #6
RootBeer 6117
Originally Posted by solidaxel View Post
Me too!!
me three its 3/16 from the T, somedays I wish I had some of the brain cells back.
Old 01-20-2011, 01:02 PM   #7
hsdropout
Thank you all for info. I assume you just crank the fitting up snug with no sealer or teflon tape? and keep your fingers crossed that it doesn't leak.
Old 01-20-2011, 02:15 PM   #8
RootBeer 6117
No sir use double flare tube only no compression fittings, you shouldnt need teflon with good ends. you can get a tool kit that you double flare the line with if you have to cut it.Most of the lines I buy at the part stores come pre made in 10" increments, if you hook two lines together use a double flare union.
This is one place you don't want to cut corners.
Joe
Old 01-20-2011, 03:02 PM   #9
MrDude_1
like the person above me said.. for the lines you need to use a double flare.
no teflon tape. no thread sealer of any kind.
the seal should be from compressing the flare fittings together.. done correctly the threads should not even be in contact with fluid.
if you're adding fittings to something (like a prop valve, caliper, etc) and it has pipe thread, you can use teflon paste. but you should try to keep pipe threads to a minimum. an ideal brake system (like modern OEM ) doesnt have any.
and never use a compression fitting on the brake system.
MrDude_1 is offline   Reply With Quote
