Old 01-22-2011, 03:47 PM   #1
superwade57
notched and bagged 2wd swb that can tow?
im sorry if this has beenposted before but i didnt come across it, i have two swb squares, a 76 and an 86, one i want to static drop and one i want to bag the other. i dont need to lay frame on 22's or anything, however, i do want to be able to bag the 86 and use it to tow the 76 on my 18 ft car trailer. long story short im looking for ideas, pictures, insider information and tip/tricks on what has worked not worked for you guysor some one you know of. i appreciate any help you guys can throw my way!
thanks a million,
Wade, WI
superwade57 is offline   Reply With Quote
Old 01-22-2011, 07:34 PM   #2
karl
karl's Avatar
Re: notched and bagged 2wd swb that can tow?
In order to bag the back as i plan on doing, you will most likely need a 4 link setup with a panhard rod and c-notch, valves, hoses, switch, tank and compressor. Big job= big bucks. They do have air assists for your leafsprings. Much cheaper for towing. But for that custom bag setup, it will cost you.
karl is offline   Reply With Quote
Old 01-22-2011, 08:34 PM   #3
78 Chevyrado
Unless the notch is welded and proven to be as strong as the frame section you cut out, towing is out of the question (safely) That's a BIG load for a notched frame to carry. The bags won't make you lose capacity, but a notch will do it real quick.
78 Chevyrado is offline   Reply With Quote
Old 01-22-2011, 09:16 PM   #4
karl
karl's Avatar
Good point about the notch. There must be a way to reinforce a small notch? You can drop the rear quite a bit without a notch and raise it for towing. My truck has a flip kit which i think is 6-7 inches? Without notch. And it does fine even with my 750 in the back. But thats stock leaf springs that are worn. Dont forget a good bumpstop also.
Old 01-22-2011, 09:32 PM   #5
78 Chevyrado
Here's a link I've been hunting for... it's from the 60-66 section, but it'll give you an idea what you need to do to tow.
Read the Whole thread, there's priceless info in there. Read all of Lakeroadsters Posts. He's the man.
http://67-72chevytrucks.com/vboard/s...d.php?t=393867
Old 01-22-2011, 09:41 PM   #6
superwade57
thanks guys def planning on a springless full frame "c" not just a flip kit notch, but im not sure how much that affects the ability to tow weight wise and if there are issues pulling on a notch? i know bags will have no issue taking the weight, as i am a small,medium duty and semi/field equipment mechanic by trade. thanks for the help keep the input coming.
Old 01-23-2011, 01:49 AM   #7
andrewmp6
The rear i would think about http://www.ridetech.com/store/suspen...ar-system.html
andrewmp6 is offline   Reply With Quote
Old 01-23-2011, 10:18 AM   #8
jitteryguy
GoatLube Experss
jitteryguy's Avatar
the notch can be made plenty strong to tow your trailor . I am gonna 4 link my 1ton with a big notch and reuse my gooseneck and bumber hitch to pull my race car.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 01-23-2011, 11:50 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by andrewmp6 View Post
That's good advice. I have that system under my 77 Cheyenne and can attest to its design and strength. It's the same style set up Ride Tech offers for the C30 system.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-23-2011, 01:27 PM   #10
superwade57
unbelievable thread the information here is incredible i highly recomend that anyone thinking about or already done a notch read this! thanks for the info!
bagged, towing
