Old 01-29-2011, 11:37 AM   #1
Laid_Out_50
Laid_Out_50's Avatar
Guy's using a Ford 8.8"
What did you use to connect your u-joint drive shaft to your rear axle?
Laid_Out_50 is offline   Reply With Quote
Old 01-29-2011, 04:13 PM   #2
chev3600
chev3600's Avatar
Re: Guy's using a Ford 8.8"
Use the flange from the original ford driveshaft and a conversion u-joint available at NAPA to connect it. I found the part number on an s10 site last year, dont remember it off hand.
Looks like it might be NAPA#372
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 01-29-2011, 05:08 PM   #3
Laid_Out_50
I found an s-10 website with different part numbers but none come up on the auto part store website
Old 01-29-2011, 06:12 PM   #4
chev3600
chev3600's Avatar
Napa parts guy can cross-reference it. Or try 2400356, I think.
Old 01-29-2011, 09:16 PM   #5
Laid_Out_50
I found the Napa part number it's a PTO Flange Yoke, 1310 PN# PUJ1379
Old 01-30-2011, 01:40 AM   #6
gibbons
hey i was thinking about using an 8.8 but was worried about the offset. Have you had any problems with it?
gibbons is offline   Reply With Quote
Old 01-30-2011, 10:57 AM   #7
ratrodmiller
ratrodmiller's Avatar
im running a 1996 8.8 disc brake explorer and it lines up great no probs, you just need the conversion u -joint and get driveshaft made,also just center the hubs to where thet are same distance sticking out on each side on frame and it lines up fine to trans tail shaft.
ratrodmiller is offline   Reply With Quote
Old 01-30-2011, 12:07 PM   #8
pinecrest
pinecrest's Avatar
Some say don't do it. Some say no prob. I'll go with those who run em. I thought the limited slip 8.8 was worth the slight gamble. I picked one up yesterday, and am excited to use it in my build!
MAKE SURE YOU DECODE THE EXPLORER REAR BEFORE YOU PULL THE TRIGGER!! Many of you probably know this, but I didn't- NOT ALL explorers had limited slip rears. I thought they all were. Glad I took pics of id tags at the junkyard and went home to decode. I'd a been mad!
One thing to look for is an L toward the beginning of the second row on the tag.
pinecrest is offline   Reply With Quote
Old 01-30-2011, 02:45 PM   #9
gibbons
yeah i have got the same tag on the one that i bought last year with 3.73 gears. I really like the axle but when i stand back and look at it i can see the offset just looking at it and i just wasn't sure about it. I'm sure they would work great. My 48 gmc aint gonna be going 100 mph down the road. Thanks for the info.
Old 09-08-2012, 02:45 AM   #10
Laid_Out_50
So with the offset in the rearend and the transmissions centered with this cause a problem with the driveline?
Old 09-08-2012, 09:43 AM   #11
mknittle
mknittle's Avatar
my thought Is the drive line dosen't know if the angle is vertical or horizontal. with that leingth drive line there should be no problems.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-08-2012, 09:47 AM   #12
Laid_Out_50
Thanks Mknittle ya the driveline is 60". Can I use hex head automotive bolts or should I buy the oem bolts?
Old 09-09-2012, 12:53 AM   #13
meter swinger
meter swinger's Avatar
Thanks for the info. I am about to go hunting for one to go in my D@DG€.
meter swinger is offline   Reply With Quote
Old 09-09-2012, 11:45 PM   #14
mknittle
mknittle's Avatar
[QUOTE=Laid_Out_50;5581220]Thanks Mknittle ya the driveline is 60". Can I use hex head automotive bolts or should I buy the oem bolts?
Posted via Mobile Device[/QUOTE
What ever you use make sure they are grade 8! I used hex bolts in my jeep. but the axle flange centered on the u-joint flange with a raised center. if yours dosen't I would use the oem bolts as that type uses the bolt shank to center. hope that helps.
Mark
My GMC build.
Old 01-27-2013, 10:34 AM   #15
Laid_Out_50
I put the drive line in my truck with the for 8.8 and it has a slight angle is this normal for this rearend?
Old 01-27-2013, 11:09 AM   #16
Laid_Out_50
It's a slight angle to the right
Old 01-27-2013, 11:12 AM   #17
chev3600
chev3600's Avatar
The pinion is offset to one side so the angle is normal. Same as when it was in an explorer, the u-joints don't know the difference.
Old 01-27-2013, 11:13 AM   #18
chev3600
chev3600's Avatar
Some guys will shorten the longer tube to center the driveshaft and allow clearance for some wider tires.
Old 01-27-2013, 11:20 AM   #19
Laid_Out_50
Thanks Chev3600
Old 01-27-2013, 01:14 PM   #20
PurdueSD
PurdueSD's Avatar
Ive got an 8.8 out of a 99 exploder in my truck. Picked up the driveshaft when i got it from the junkyard so ive got the flange. Its 59.5 mouting surface to mouting surface. Its a little too narrow, so i wil probably run some 3/4" spacers.
My Lost and Forgotten build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=442712
PurdueSD is offline   Reply With Quote
Old 01-27-2013, 11:23 PM   #21
heavymetalresto
Has anyone done the 8.8 rear in the 55-59 truck and if so whats involved?
heavymetalresto is offline   Reply With Quote
Old 01-30-2013, 11:30 AM   #22
usmarine
I put one in my 54. I used the entire setup from the donor exploder. Springs, shackes, swaybar and shocks! just had to fab a bar for shocks and swaybar and box frame and add a bushing for rear shackle.
usmarine is offline   Reply With Quote
Old 01-30-2013, 02:12 PM   #23
blackdiesel
blackdiesel's Avatar
I've put then in two 57's. The early 00's mercury mountaineers have factory traction bars, which is what i slid in my 38 Chrysler. Cut and move the spring perches and your ready to go!
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
