Old 02-04-2011, 08:28 PM   #1
BigShoe24
True Addiction
BigShoe24's Avatar
LS376 / 480 With 4L80E
Hey Guys,
Just got my LS376 in, and already have the 4L80E in the truck. I went to install the GM p/t #12602448 flex plate to my torque converter and it didn't quite match up. The holes on the flex plate are about a 1/8 to 1/4 of an inch in from lining up.
Any idea of how to proceed? Should I get a different flex plate or would it be possible to 'open' the holes up in order to for both pieces to line up?
RCC
BigShoe24 is offline   Reply With Quote
Old 02-04-2011, 09:06 PM   #2
blazerboy72
Re: LS376 / 480 With 4L80E
You can open them up as long as the crankshaft to torque converter spacing is right. All of the 4l80e flex plates I have seen are 6 bolt you may want to double check.
blazerboy72 is offline   Reply With Quote
Old 02-04-2011, 09:13 PM   #3
clinebarger
The holes not lining is not the real problem, The "snout" on the 4L80E converter is not long enough to engage into the crankshaft.
This is what GM uses to mate a 4L80E to a LS engine http://www.gmpartsdirect.com/results...umber=12621399 & the only Flexplate that I know of that will work with your 6-bolt converter
Heres another thread on the subject http://67-72chevytrucks.com/vboard/s...d.php?t=426994
clinebarger is offline   Reply With Quote
Old 02-04-2011, 09:13 PM   #4
cableguy0
Its the wrong flex plate for a 4l80e. A 4l80e has 6 bolts.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-05-2011, 11:55 AM   #5
BigShoe24
True Addiction
BigShoe24's Avatar
Thanks guys, I'll post pics of the motor and install once I get the new plate and spacer.
RCC
Old 02-06-2011, 12:16 AM   #6
BigShoe24
True Addiction
BigShoe24's Avatar
So I pulled the flex plate that came on the motor. It matched the one sold to me that I was told would bolt right up to the 4L80E, go figure. Hopefully the GM dealer will be a nice guy and swap me out for this one; GM part number 12621399
RCC
Old 02-09-2011, 11:25 PM   #7
BigShoe24
True Addiction
BigShoe24's Avatar
Got my flex plate in and looks good.... I need to grab some more bolts tomorrow to bolt up the converter though. Do you guys recommend using washers, lock washers, or just loctite? Also, the GM specs recommend bolting the flex plate to crank at 74 ft/lbs. Does that sound right to everyone?
RCC
Old 02-10-2011, 06:20 PM   #8
clinebarger
You need the correct torque converter bolts, New ones will have threadlocker already applied to them, Like these http://www.autozone.com/autozone/acc...er=732339_0_0_
Torque converter bolt torque is 32 ft. lbs
74 ft. lbs. is the final torque on the flexplate bolts, Heres the entire procedure.
First Pass...20 Nm (15 ft. lbs.)
Second Pass...50 Nm (37 ft. lbs.)
Final Pass...100 Nm (74 ft. lbs.)
Be sure to apply thread sealant to them, I use this http://www.permatex.com/products/aut...ad_Sealant.htm
Old 02-12-2011, 01:23 PM   #9
BigShoe24
True Addiction
BigShoe24's Avatar
clinebarger, thanks bud. When I was doing final pass I started to turn the motor over. I suppose I should place a bar stop through the fly wheel to tighten. I really hate to over tighten these bolts into the crank though. Any words of wisdom....
RCC
Old 02-13-2011, 08:10 PM   #10
BigShoe24
True Addiction
BigShoe24's Avatar
Motor fits very well. Installed converter then dropped in the motor. Once all the bolts were nice and snug I went to go bolt up the converter to the flex plate. When I checked it out it had perfect clearance, about a 1/16". Hopefully I can get some headers picked out soon. I will be ordering the Concept One accessory set, and a computer from Speartech very soon.
Any word on the Doug Thorley "big tube" headers. From what I've read I should try to run at least a 1 & 5/8" header.
RCC
Old 02-21-2011, 12:28 AM   #11
shrunken66stroker
shrunken66stroker's Avatar
I assume you have L92 or LS3 heads on there. I don't know the cam specs but to pump out 480hp out of 376ci it's probably got a lot of lift and duration. Most people making that kind of power are running headers with at least 1 3/4" primaries and 3" collectors. I think any smaller and you'll be choking off horsepower. Doug Thorley has been talking about making some swap headers with larger primaries using the 324y for a template, but I haven't seen them yet. They're supposedly in the prototype/testing phase. There's a thread on it here with someone from DT talking about it. Dynatech swap headers for 70-81 camaros are being used and they're around $400 coated. They hang down a few inches below the frame but other than that I can't see any drawbacks. Good luck with your swap.
shrunken66stroker is offline   Reply With Quote
Old 02-21-2011, 12:30 AM   #12
shrunken66stroker
http://67-72chevytrucks.com/vboard/s...d.php?t=445414
Old 11-19-2011, 11:13 PM   #13
BigShoe24
True Addiction
BigShoe24's Avatar
Hey guys, anyone have any insight or suggestions on what accessory drive kit to run? I am trying to decide between Concept One and Billet Specialties Tru Trac. Also, if there are any other products I'm always open ears. Thanks
RCC
Old 11-22-2011, 03:15 AM   #14
mcmlxix
Collector of Projects
mcmlxix's Avatar
Try looking at these guys... I have LS376/480 for my Chevelle, this is the kit I was going to run... in black with all the accessories....
http://s41657.storefront-solutions.c...?CategoryID=38
Rich
1972 K5 Blazer CST Click HERE
Old 02-03-2012, 07:48 PM   #15
BigShoe24
True Addiction
BigShoe24's Avatar
Got some new hardware today. Hopefully will get them on tomorrow.
RCC
Old 02-03-2012, 11:23 PM   #16
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Wow, those are purdy! Sure look more beefy than the smaller DT's too.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-04-2012, 06:51 PM   #17
BigShoe24
True Addiction
BigShoe24's Avatar
They are beefy and they DON'T fit. To bad...
RCC
Old 02-04-2012, 07:12 PM   #18
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
say what? Are they the new larger swap headers?
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 02-04-2012, 10:46 PM   #19
BigShoe24
True Addiction
BigShoe24's Avatar
Yep. The right side (when sitting in the truck) hit in the rear; on the firewall. I have a Porterbuilt Dropmember which moves the motor back. I really thought they'd fit.
RCC
Old 02-04-2012, 11:46 PM   #20
usmcchevy
usmcchevy's Avatar
Sorry to hear that. Does the dropmember just move the motor back or back and up?
Build thread
LSx Swap FAQ index
Old 02-04-2012, 11:49 PM   #21
BigShoe24
True Addiction
BigShoe24's Avatar
Back and Up. Now that I'm looking at the headers; the rear passenger tube goes way back when it should just go down and flow like the driver side. Oh well...
RCC
Old 02-05-2012, 02:04 AM   #22
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
looks like that #6 tucking behind #8 adds a couple inches. The Dynatech's don't do that.
and I'd think you need at least a 1 3/4" primary or even 1 7/8", w/3" collector or larger. I've even started seeing LSx headers with big block sized 2" primaries!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-18-2012, 06:32 PM   #23
BigShoe24
True Addiction
BigShoe24's Avatar
Well here is my latest progress.
RCC
Old 02-18-2012, 07:56 PM   #24
mooseknuckles
mooseknuckles's Avatar
awesome!...I'm ordering me a set of those to try...they're $300 cheaper than the hookers and the quality looks good too..
mooseknuckles is offline   Reply With Quote
Old 02-18-2012, 08:09 PM   #25
BigShoe24
True Addiction
BigShoe24's Avatar
Great quality. I'm very happy with the fit as well.
RCC
