02-14-2011, 01:01 AM | #1 |
Cleaning/protecting billet pulleys and brackets
What's the best way to clean and protect this stuff? I have a brand new Billet Specialties Tru Trac setup and I noticed that when I was mocking it up on the motor that when I would screw the bolts in with my fingers that my skin skuffs the billet. I thought about having it powder coated in a clear but the tolerances on this stuff is so tight that I'm a little leary of powder or clear coat. That may be the way to go but I'm just wondering if there is another way.
02-15-2011, 01:22 AM | #2 |
Re: Cleaning/protecting billet pulleys and brackets
Nobody's running/cleaning billet brackets?
03-10-2011, 11:15 AM | #3 |
Spanked once
You can get buffing kits at Homer depot and separate wheels. We (the wife) just polished our Sanden A/C compressor from raw to shiny
Mainly used 3M buffing compound ,the same stuff as for paint.
The ole 350 budget build. |
03-10-2011, 11:20 AM | #4 | |
if you google the stuff, you'll find out more then i can ever type on it. It works great. |
03-10-2011, 01:12 PM | #5 |
I bought Mothers billet polish for mine. My project is going on 12 years and I have billet brackets and pullies from Street and Performance. I was looking to bring the bling back. I was going to use this with a power ball but I have not had good luck with the power ball so I did it by hand. I was impressed with how well it turned.
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
03-10-2011, 07:03 PM | #6 |
Parts and more parts
Welcome to the land of aluminum and all of the great things that happens when you touch it.
I use a set of 3" small razor buffs on a die grinder and using the stick polishing compounds to get aluminum to a shiney condition. Once there, I use Mothers aluminum polish to get any dirt or larger scratches out of the metal to start and then follow up with the Mothers "Billet" polish to give a mirror finish. I then seal my aluminum with a metal sealant that impedes corrosion and dirt getting into the pores of the metal. There are numerous brands out there, but I use one from a company called "Wizards". I have been running billet aluminum pulleys, water tanks, and an aluminum radiator for years, not to mention Billet specialties wheels on my trucks for quite some time.
Frank |
