02-14-2011, 07:08 PM | #1 |
laying low
active transfer case
I saw this in a brochure for my 2000 GMC. What exactly is this? Mine is 4wd with Auto 4wd button as well as the normal 2 hi, 4 lo, 4 hi buttons.
Also I noticed the driveshaft from t case to front diff does not turn by hand like my 97 does. While under it for oil and lube I give it a turn on the 97 but the 2000 will not as though it was engaged. It is disengaged though. The 4wd works perfectly on both trucks. What's the difference?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
02-15-2011, 11:43 PM | #2 | |
Re: active transfer case
my '99 is like that with the drive shafts too. and i believe(not positive) active t-case is the top button which is AUTO 4WD or something like that. it engages when it senses tire slip, and disengages when it has enough traction. never used/liked it though.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains Quote:
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there Last edited by jakeblues652; 02-15-2011 at 11:44 PM. |
