02-24-2011, 01:02 AM | #1 |
Gas Gauge
I did some searching and couldn't find an answer. The gas gauge in my seventy burb is always on empty and I want to fix it. I unplugged the brown wire that comes from the gauge and plugs into the fuse box and the gauge goes to about the three o'clock position. So my assumption was is they wire coming forward was grounded. So I went to the tank and as close as I could I cut the brown wire and then ran a new one up to the wire that was unplugged from the gauge and nothing changed it stayed a three o' clock. In fact even if I ground the wire going right to the gauge it stays at three o'clock too, but as soon as I plug it back in the fuse box it goes to empty. So what am I doing wrong? Is the brown wire not the right one going back to the tank. Or what else could it be?
02-24-2011, 01:18 AM | #2 |
What?
Re: Gas Gauge
Just a few questions off the top of my head at this point, assuming that your float is ok and we are focusing on wire.
Have you made sure that the rear harness hasn't been butchered by trailer lights or has been pinched by the body? (Check to see if the fuel gauge wire has been mended, then over time come loose). Have you separated the rear harness connector and tested the continuity from the connector back to the tank connector? (Isolate the rear harness). Also, have you run a scrap wire from the negative terminal of the battery to the tank? (Testing good ground). Finally, looking in the passenger side rear wheel well. Look at the top of the tank, and see if the connector is still in good shape. It's a rubber boot, that has a brass snap terminal inside it. This connector fits over a pin, then snaps onto it. You will have to take a thin long probe to get to the connector, then move it around while someone looks at the gauge. See if the gauge responds to you moving it.
Chris 1968 K20 Suburban 1972 K10 LWB PU Last edited by vectorit; 02-24-2011 at 05:07 PM. |
02-24-2011, 12:08 PM | #3 |
Re: Gas Gauge
Chances are the float has sunk.
70 Jimmy 4x4 71 GMC 2500 Too bad stupidity isn't painful |
02-24-2011, 03:30 PM | #4 |
Re: Gas Gauge
Mine just started to act up this week on my burb... it now reads empty, or close to empty. Needle no longer moves. I was thinking fuel sending unit, or float. I have not had time yet to trouble shoot...
Doug '72 GMC K2500 Suburban 4x4 |
02-24-2011, 03:36 PM | #5 |
Stalker Nate
Re: Gas Gauge
Mine moves from empty to 1/4 full and never more, even on a full tank lol Damn old chevy gauges. For how much gas this truck sucks back though, I'd be afraid to see how fast it'd move if it actually worked properly
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
02-27-2011, 12:13 AM | #6 |
Re: Gas Gauge
Mine was working, now it's not! Previous owner cut a hole in the floor to work through.... If I take the wire from the sender and touch it to ground, gauge goes to full while wire completely disconnected registers empty. Gauge is stuck on 1/8 with wire connected.
I've proven to myself that from the sender forward everything is working, so it is a sender problem. The idiot that cut the hole didn't quite cut it far enough right for me to pull the sender and a hitch was WELDED under the tank..... Dontcha just love the modifications you find on used stuff? |
03-01-2011, 02:00 AM | #7 |
Re: Gas Gauge
worked with it again today with no luck, does anyone have a diagram on the wiring? How many wires go into the sending unit, I think I only see two a red and a brown and the brown I am assuming is going to the front?
03-01-2011, 02:17 AM | #8 |
What?
Re: Gas Gauge
It's late, and I am fuzzy.. But, IIRC there is only one wire to the sending unit.
Hence why grounding is important. You should be able to trace the wire to the underside of the driver side tail light area, from under there is a hole the wire for the tank and the license plate come out. Make sure they are still intact, since that area gets rusty and jagged. From the inside, pull the driver side rear panel to expose the tail like region. Make sure all is ok there, then if you do not have a headliner the loom traverses the driver side. You should be able to dig it out with your hand, then inspect it all the way to the A pillar for chafing.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
03-01-2011, 07:49 AM | #9 |
Rottenwood Garage Member
Re: Gas Gauge
Have you pilled the sending unit and put a multi meter on it?
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
03-02-2011, 12:09 AM | #10 |
Re: Gas Gauge
03-02-2011, 02:03 AM | #11 |
Moderator
Re: Gas Gauge
I had a similar problem. My problem was the resistor on the back of the unit was defective.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
03-03-2011, 01:27 AM | #12 |
Re: Gas Gauge
03-03-2011, 02:28 AM | #13 |
Moderator
Re: Gas Gauge
Sorry for the delay. I am refering to the back of the cluster. There is a little white rectangular resistor (attached to the rear of the fuel gauge) It is made out of fiberglass/fabric with thin coiled copper wires around it. Or, yours might be the other type: ceramic with metal inlaid copper connectors. They can go bad.
If that doesn't correct the problem, and you try all of the trouble shooting tips as mentioned above, it may be your fuel gauge itself.
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 03-03-2011 at 02:29 AM. |
03-03-2011, 09:39 PM | #14 |
Re: Gas Gauge
This is all good info as my gauge isn't working either! Mine is stuck on full, and since I found broken wire at the right rear turn signal, I'm betting it's wiring at the elft turnsignal area where the harness goes through.
Some joker had trailer wiring on it and when he removed those displacement splices it broke the wiring. I'm guessing that's the same for the left side too. |
03-09-2011, 01:02 AM | #15 |
Re: Gas Gauge
Single wire to the back is brown..... If it registers full, the wire is bare and touching ground somewhere or the float is stuck up (not likely) If it registers empty, the wire is broken or disconnected. The wire is unpluggable behind the gas tank.
03-15-2011, 01:54 AM | #16 |
Re: Gas Gauge
So when I unplug the gauge from the fuse box and it goes to the three o clock position is it grounding out and that why it does that or is that what it is supposed to do when its unpluged?
03-15-2011, 10:09 AM | #17 |
its all about the +6 inches
Re: Gas Gauge
it's supposed to do that when unplugged
03-15-2011, 10:41 AM | #18 |
Re: Gas Gauge
I had the same problem with mine not reading correctly. Had to get the whole new sending unit from summit racing. They were the only ones that had a unit that was close to the original.
72 chevy 3/4 ton 4X4 |
04-07-2011, 04:18 AM | #19 |
Re: Gas Gauge
When i turn my ignition on it jumps right to the 3 o clock, but when its off, it slowly (over weeks) moves to maybe 12-1 o clock
"Feel it's not a bonfire unless they can see it from space?" ~ Capt. Morgan 1970 Cst - 20 402 1984 Chevy C30 6.2L Diesel crew cab Dualie |
04-09-2011, 10:26 PM | #20 | |
Re: Gas Gauge
1-With no power to the gauge (fuse pulled) the gauge reads full. Connect power and it goes to empty with a full tank of gas. 2-The wire at the tank doesn't go from the Pass. side, it goes through the driver's side rear tailight area. 3-When I pulled the wire the gauge goes to empty. 4-When I ground the wire the guage goes to full. Read the sending unit with a full tank of gas and I get 8 ohms resistance to ground. Not sure if the sending unit reads 90 ohms full or empty. Anyone know for sure?
1969 C10 Suburban 350 1963 Falcon gasser 464 BBC 1946 Austin 327 SBC gasser Last edited by 1971BB427; 04-09-2011 at 10:27 PM. |
04-10-2011, 01:46 PM | #21 |
Re: Gas Gauge
ok so my guage isnt working now...but there is a wire with a round tip on it just hanging....was this connected to the back of my fuel guage, my guage is reading full. i tested the tree pins on back and one registers 6 volts and the other 12 volts when the ignition is on. help!
1972 chevy c10 Last edited by robertrocha6; 04-10-2011 at 01:51 PM. |
04-11-2011, 10:36 PM | #22 | |
Re: Gas Gauge
TANK WIRE GROUNDED=FULL TANK WIRE DISCONNECTED OR BROKEN=EMPTY Last edited by AzDon; 04-11-2011 at 10:40 PM. |
04-11-2011, 10:48 PM | #23 |
Re: Gas Gauge
With everything hooked and hot at the dash, If you can unplug the brown gauge wire behind the bumper and it goes empty and then, when you touch this wire to bare metal, it goes to full, This test result indicates that your gauge and wiring are working properly back to this point and your problem is the wire from the plug to sender, the sender itself, or the sender's grounding wire
04-11-2011, 11:00 PM | #24 |
Re: Gas Gauge
Thanks guys! I guess my next step is to run the Burb enough to get the tank close to empty and drop it. Sounds like I've either got a bad sending unit, or a float that's sunk.
I had contemplated cutting the deck above the sending unit to make an access hole to work on the unit, but I think I'd ratherr not damage a perfect deck.
1969 C10 Suburban 350 1963 Falcon gasser 464 BBC 1946 Austin 327 SBC gasser |
05-04-2011, 12:24 AM | #25 |
Re: Gas Gauge
Finally worked on mine again today and got it figured out. I dropped the tank and the float had sunk, it had all sorts of rust on it and had ate through it so it could never rise. So I grabbed a sending unit I had laying around from a 71 truck and the float part was the same so I installed it put everything back together and it works like a champ!! Thanks for all the advice guys.
