Old 03-04-2011, 11:18 PM   #1
60ratrod
yes, i do
60ratrod's Avatar
electrical power loss issue
so occasionally i have a problem when i go to start my 01 tahoe and i have no power what so ever. so what i have to do is pop the hood and loosen the negative cable then tighten it back up. so now is this a corrosion problem at the battery or is it a problem further down in the cable itself? and i don't giggle the cable at all, just loosen it a few turns then re-tighten, and then try to giggle the connector at the battery after its been tightened, not the cable.
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 03-05-2011, 12:55 AM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: electrical power loss issue
Have you tried cleaning your battery connections? Also check where your cables connect to ground and to the starter.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
