Old 03-10-2011, 01:40 AM   #1
Puropedo
Running stock 67-72 Tach with an LSx?
Hey guys, is this possible? I would love to keep all my stock mechanical gauges working, so far I have figured oil,temp,volt and speedo.....
Puropedo is offline   Reply With Quote
Old 03-10-2011, 03:50 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Running stock 67-72 Tach with an LSx?
Yes you can. You will have to have the tach resolution set from 6 to 3 in the tune. You can do it with HPTuners or have someone who does tuning do it for you. What this does is double the tach output, since Ls engines put out a 4 cylinder output. Otherwise your tach will read half of what it should.
Also if you're using a 2003 or newer PCM, you may need a pull up resistor to make the signal strong enough for the tach to see it.
ls1nova71 is offline   Reply With Quote
Old 03-10-2011, 07:49 PM   #3
John @ BROTHERS
John @ BROTHERS's Avatar
Originally Posted by ls1nova71 View Post
Otherwise your tach will read half of what it should. Posted via Mobile Device
So theoretically, the stock 5k tach will be a 10k tach?
Thanks,
John
1967 Chevy Short/Fleet
1969 Chevy Short/Step
2004.5 Dodge 2500 4x4 Cummins 6spd
John @ BROTHERS is offline   Reply With Quote
Old 03-10-2011, 10:24 PM   #4
ls1nova71
ls1nova71's Avatar
Thanks,
John
I suppose if you were to change the numbers on the lens, then yes it would be! Lol
Old 03-10-2011, 10:51 PM   #5
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
What did you do to figure these out? How did you do it? I found some metric to standard adapters for the temp and oil psi..is that what you used or?
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 03-11-2011, 03:25 AM   #6
Puropedo
Sweet!...Thanks for the input brother!
I drilled and tapped the boss above the oil filter for oil pressure, drilled and tapped the hex bolt for temp, tail housing kit for speedo, also, I simply applied power and ground to the voltmeter, hope that helps!..
