Old 03-13-2011, 06:09 PM   #1
biohazardbill
12 bolt axle question
Are all 12 bolt c-10 axles the same from 60-66 other than gearing?
biohazardbill is offline   Reply With Quote
Old 03-13-2011, 11:34 PM   #2
Captainfab
60-66 Nut
Re: 12 bolt axle question
Not quite
The 12 bolt truck differential was first used in the '63 model year. The easiest way to ID a '63 12 bolt is by the pressed on backing plates. The '63 & '64 12 bolts used 17 spline side spider gears and corresponding axles. The '63 & '64 differentials had the panhard bar mount on the passenger side axle tube. The '65-early '70 are essentially all the same. Late in 1970 is when the increased the overall width by 1.5".
