Old 03-22-2011, 06:57 AM   #1
Big bad Green
Big bad Green's Avatar
Lift kit help
hey guys i just bought a parts truck. its a 94 chevy the trucks junk but I want to take the lift out of it well The PO is a kid that goes to my school he said he welded it in. It it possible To now get it out? Im told its a procomp Lift 7inch.
thanks
thats the truck when it was good
1968 Chevy K20 Long bed dump truck
1978 Chevy Custom deluxe long bed
1986 Chevy Custom deluxe short bed
1987 Chevy Custom deluxe short bed
1987 Chevy Silverado short bed
1990 Chevy Silverado K5 Blazer
All four wheel drive! All non mutt trucks!
Big bad Green is offline   Reply With Quote
Old 03-22-2011, 11:35 AM   #2
69CSTDawg
69CSTDawg's Avatar
Re: Lift kit help
just lookin at the pic it doesnt really look like that high a lift to me,is it possible theres a body lift on it? theres a gap between bed and frame that makes me think body lift
69CSTDawg is offline   Reply With Quote
Old 03-22-2011, 12:49 PM   #3
Big bad Green
Re: Lift kit help
there is a body lift too
Old 03-22-2011, 02:11 PM   #4
Davidmichael
Davidmichael's Avatar
Re: Lift kit help
It's probably a 4" lift with a 3" body lift. (unless the picture is different from now) Not sure really cause I am not a fan of the IFS suspensions. But it's probably some where around that. Yes you can remove the old lift and put it on your truck, but it's going to be a chore. What you can try to do is find the manufacturer and then download the installation instructions. You will need those. You might have to modify your rig some what. I know some of those lifts require mods to get the proper fit.
If you go threw with this, make sure you do a lot of research first, and make sure you cut out the lift cleanly.
And just an FYI unless it's a really old lift, procomp only has a 4" and a 6" lift listed on there website.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 03-22-2011, 02:20 PM   #5
Big bad Green
Re: Lift kit help
Its a 6inch with 3inch body tbars cranked 3inches
Old 03-22-2011, 02:27 PM   #6
69CSTDawg
69CSTDawg's Avatar
Re: Lift kit help
only major task other than swapping over should be cuttin the tab off the front diff and putting on the new one from the kit as far as i know (not a ifs lift expert by no means)
Old 03-22-2011, 03:26 PM   #7
Altec
Getcha Pull
Altec's Avatar
Re: Lift kit help
I don't really see what he would have had to weld? Most all kits for IFS are simply drop brackets to lower the entire front assembly. Maybe he welded those goofy compression arm things?
The only issue I would see is most all of the IFS lift kits require the cutting of at least one of the factory tabs.
I wonder if he is referring to linkage extensions for the 3" body lift? Take a peak around the steering box under the hood, and the transfer case shift linkage under the truck.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 03-28-2011, 12:20 AM   #8
rayfinseats
Re: Lift kit help
Curioius what you paid for that parts truck...
rayfinseats is offline   Reply With Quote
Old 03-28-2011, 02:41 AM   #9
brett3xx
Re: Lift kit help
That's a 4-6" procomp lift. It's their older design and they marketed it as 4-6". The height depended on what rear block was used and how the torsion was set. It's not suppose to be welded on, but I have seen a few people that welded it anyways, maybe yours isn't welded though.
brett3xx is offline   Reply With Quote
Old 03-28-2011, 04:26 AM   #10
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Re: Lift kit help
It is hard to say with out seeing what is welded.
By the time you do all of the work to make that happen though you could have easily done a straight axle conversion and have a better truck on your hands, just something to think about. Id get what you need off the parts truck and sell it to fund the straight axle.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 03-28-2011, 06:59 AM   #11
Big bad Green
Re: Lift kit help
Not much is welded Ill get pics i just got the thing
Old 03-28-2011, 07:01 AM   #12
Big bad Green
Re: Lift kit help
Not saying
Old 03-28-2011, 10:15 AM   #13
Redcap
Re: Lift kit help
Originally Posted by Big bad Green View Post
Not saying
That usually means "way too much".
Redcap is offline   Reply With Quote
Old 03-28-2011, 11:22 AM   #14
Big bad Green
Re: Lift kit help
I dont own it i own the lift bed and doors and trans other than that trucks junk
Old 03-29-2011, 08:17 AM   #15
Big bad Green
Re: Lift kit help
I cant wait I take all the parts off of it to build my monster I might want to start a build thread.
Old 04-07-2011, 08:06 AM   #16
Big bad Green
Re: Lift kit help
Bit of a up date the welds are not that bad it only welded In 2 places
Old 04-07-2011, 11:59 PM   #17
Mkcustums
Mkcustums's Avatar
Re: Lift kit help
Just don't do this to it! IFS lifts are pretty much useless.
I think you can tell what's going on there...
Mkcustums is offline   Reply With Quote
Old 04-08-2011, 12:42 AM   #18
72shortbed12
Re: Lift kit help
I picked up the same yr color and lifted 6 inch truck, took the motor, parted the rest out and made 1200. Its worth it. The lift is a pain to remove.
1972 K10 4wd Swb 350, 4 speed, 205 t-case Sold
1971 Cheyenne 2wd Lwb 350 4 speed Sold
1972 K5 blazer 4WD auto A/C
72shortbed12 is offline   Reply With Quote
