Old 03-24-2011, 09:15 AM   #1
fun in dirt
fun in dirt's Avatar
Pics for 72longbed of winch bumper
Welded heavy square tubing between frame rails, then welded receiver tube to that. Bent up box for winch & put into receiver, then built bumper around it. Winch box held in place by receiver pin & 5/8 grade 8 bolt on each side that screws into weld nuts into the bumper tubing.
Works great - as you can see by the scratched & mud its been used & abused. I have been against a tree pulling with the winch, hard enough that the winch quits pulling & the bumper has never budged!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 03-24-2011, 09:17 AM   #2
fun in dirt
Re: Pics for 72longbed of winch bumper
few more
'85 K30 "Big Nassy"
'06 C1500 WT...DD
Old 03-24-2011, 10:10 AM   #3
Burt4x4
Burt4x4's Avatar
So you can remove the whole thing with a pull of the pin?
I like the eexpanded steel look.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 03-24-2011, 11:01 AM   #4
fun in dirt
...And take out the 2 bolts. "Whole thing" being the winch box section, that way can put it on the rear too if needed. But we also have a receiver tube on front of our car hauler trailer so can put the winch on it & drag something onto the trailer if needed.
'85 K30 "Big Nassy"
'06 C1500 WT...DD
Old 03-24-2011, 02:32 PM   #5
Burt4x4
Burt4x4's Avatar
Cool!
Old 03-26-2011, 09:21 PM   #6
'63GENIII
'63GENIII's Avatar
Slick setup! That's alot cleaner than the regular receiver style mounts that you see. Are you using those quick connects for the cables too? Man I like that setup!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 03-28-2011, 12:30 PM   #7
fun in dirt
THANKS!
Yeah it has quick connects, but just use a welding cable quick connector for the hot & it grounds itself since all connected to the frame.
'85 K30 "Big Nassy"
'06 C1500 WT...DD
