Old 03-27-2011, 11:35 AM   #1
TexasJimmy
TexasJimmy's Avatar
2.5" or 4" suspension lift?.....and what brand?
Thinking about lifting the 71'.
Any suggestions on lift size and brand? Gas, or fluid filled shocks?
I want to keep my current tires and wheels. 33x12.50x15.
Any other mods I need to think about when lifting 4".
I have been pricing lift kits at 4 Wheel Parts. Is there a better place to buy a lift.
Here are some pics. of my Blazer
Thanks in advance,
"It is, what it is" K5 NV
71' Blazer CST
84' GMC Jimmy-SOLD
2008 Suburban LTZ
TexasJimmy is offline   Reply With Quote
Old 03-27-2011, 12:08 PM   #2
sandking
.....I am working on it.....
sandking's Avatar
Re: 2.5" or 4" suspension lift?.....and what brand?
It looks great just the way it is!!!
View my build thread HERE
sandking is offline   Reply With Quote
Old 03-27-2011, 12:15 PM   #3
TexasJimmy
TexasJimmy's Avatar
Thanks.
I know, I am on the fence about the lift. Believe this, my wife is the one that suggested the lift...lol
71' Blazer CST
84' GMC Jimmy-SOLD
2008 Suburban LTZ
Old 03-27-2011, 12:59 PM   #4
AlaskaMatt
AlaskaMatt's Avatar
First thing. If you fit the 33s and it drives sweet DON'T mess with it. It's a beauty! As you go up stability goes down. It's just physics.
That said, I am very happy with a 2.5 skyjacker. Rides nice, no need for steering arm replacement either. I brought mine down to a 2.5 lift as it had a 4in front 8 inch rear lift when I purchased. it. It was cheaper to buy a smaller all around spring lift than have stock springs made. But it worked out just fine.
One thing to think about whatever size you go is these tend to be butt draggers. My lift is actually a 2.5 front and 4 rear. If I set a level on the bed rails it's almost perfectly level. 2.5 in the rear would have left me with a rake to the rear.
As it is I may even add some zero rates the bring the rear up just a bit.
Thanks,
Matt
My Website
AlaskaMatt is offline   Reply With Quote
Old 03-27-2011, 01:18 PM   #5
1972CST
1972CST's Avatar
I think a 2-3" lift looks right running 33's and stock 8" wheels. It probably wouldnt hurt to freshen up the leaf springs and shocks anyway. I am running a 2" TC all spring lift... no brake line or steering components needed. I have added a zero-rate add a leaf in the rear to level it out since I took this pic.. Great looking Blazer by the way.
1972CST is offline   Reply With Quote
Old 03-27-2011, 02:23 PM   #6
TexasJimmy
TexasJimmy's Avatar
Matt and CST,
Thanks for the great information. If lifted I will go 2.5 w/add-a-leaf rear sounds like the way to go. I am dragging butt now sitting stock.
What shocks do you recommend? Did you go single or double on the steering shock.
Btw, it does ride sweet the way it is with the 33's.
You both have some nice rides.
Thanks,
71' Blazer CST
84' GMC Jimmy-SOLD
2008 Suburban LTZ
Old 03-27-2011, 02:49 PM   #7
AlaskaMatt
AlaskaMatt's Avatar
I went double steering shock, but it's probably overkill.
As to suspension shocks I just used the skyjacker shocks that came with the kit.
Thanks,
Matt
My Website
Old 03-27-2011, 03:20 PM   #8
bigeasycigars
bigeasycigars's Avatar
I like Bilsteins for shocks.
Deavers or Alcan for custom made springs.
Skyjacker Softrides for ready made.
Springs all around.
Sometimes when you go to 4" you have to change driveshafts as well as steering. If your streeting it most, I'd stay low as ya can. Single is fine for a stabilizer unless your going bigger tires (35"or more) and higher lift (6" or more). Otherwise it's for looks.
I just changed mine to a 4" Skyjacker Softride, Bilstein Shocks, Replaced Rubber Body Mounts, Swaybar Disconnect, and ORD Greaseable Bolt/Shackles.
I'll see in a week how it came out.
'71 K/5 CST Work in progress...In Sicily, women are more dangerous than shotguns.
bigeasycigars is offline   Reply With Quote
Old 03-27-2011, 09:16 PM   #9
TexasJimmy
TexasJimmy's Avatar
Springs all around.
Thanks for the take.........let me know what you think. Are there greasable body mounts? I like grease.........
71' Blazer CST
84' GMC Jimmy-SOLD
2008 Suburban LTZ
Old 03-27-2011, 09:19 PM   #10
TexasJimmy
TexasJimmy's Avatar
Bigeasy.....your rig looks awesome....what brand is your soft top? I can't stand my grill insert. I want your egg crate insert with the bow tie....
71' Blazer CST
84' GMC Jimmy-SOLD
2008 Suburban LTZ
Old 03-27-2011, 09:25 PM   #11
TexasJimmy
TexasJimmy's Avatar
What size tire are you running? I think I have those rims on my 84' Jimmy. It is also running 33x12.50x15's.
71' Blazer CST
84' GMC Jimmy-SOLD
2008 Suburban LTZ
Old 03-28-2011, 12:12 AM   #12
bigeasycigars
It's a Softopper... www.softopper.com
Here are a few grilles for sale on this site.
http://67-72chevytrucks.com/vboard/s...d.php?t=454145
http://67-72chevytrucks.com/vboard/s...d.php?t=452339
Thanks for the kind words,
Eric
Old 03-28-2011, 01:58 PM   #13
TexasJimmy
TexasJimmy's Avatar
Eric
Eric,
Thanks for the information.
71' Blazer CST
84' GMC Jimmy-SOLD
2008 Suburban LTZ
Old 03-29-2011, 06:31 AM   #14
mcmlxix
Collector of Projects
mcmlxix's Avatar
Most lift springs ride rough and will have you bouncing around unless you go for some custom springs. My Blazer had a 4" lift on it whe I got it. Its a littel bouncy. It has a raised steering arm but stock drive shafts.
Make sure your body mounts are in good shape. That alone can cost you a inch. I did replace the body mounts and added 1" body lift blocks from ORD ( http://www.offroaddesign.com/catalog/oneinchlift.htm ) If you still need a little more use the add-a-leaf or Zero-Rate for the rear to even it out...
I second Bilstein for shocks. I will be replacing my shocks ASAP with a set of 5150s.
Rich
1972 K5 Blazer CST Click HERE
Old 03-29-2011, 08:50 PM   #15
rads42
Do you have a before and after pic with the 1" spacers installed. Did all your door gaps, etc come back to normal after the body bushing and spacer install?
rads42 is offline   Reply With Quote
Old 03-30-2011, 04:27 AM   #16
mcmlxix
mcmlxix's Avatar
No new pics since the blocks and mounts... I'll try and get some. As far as the body lines, I didn't have much to start with. I did have a few shims that I didn't put back in. The pass side door was fine but the drive door didnt want to close nice....
Rich
Old 04-01-2011, 06:47 AM   #17
mcmlxix
mcmlxix's Avatar
here are some pics ... w/ 33 x 12.5 x 15
Rich
