Old 03-29-2011, 03:37 PM   #1
wiggins
wiggins's Avatar
38'' Big daddies
My brother in law is looking at buying a 85' 1/2 ton Chevy stepside with a good running stock 350/350 combo. The truck is carrying 38'' A/t rites. The owner is not sure of the rear end size but says he get 13-14 mpg so I am thinking 373 gears. Will these gears hold up to everyday hwy driving with these tires. I am thinking maybe a 411?
Preserving American History one truck at a time.
wiggins is offline   Reply With Quote
Old 03-29-2011, 03:43 PM   #2
Altec
Getcha Pull
Altec's Avatar
Re: 38'' Big daddies
65MPH=2200RPM with 3.73 gears. 4.10's would bring you to 2400RPM. I would consider 4.33's if I was to change gears.That is 2550RPM. All of this not counting a non-lockup transmission... But, I'd be inclined to ditch the balloons for something smaller if it was my street truck.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 03-29-2011, 11:58 PM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
Couple of ?'s. 14 mpg with a 350/350 combo, 3.73's and 38's? Somebody might need to recheck the mileage number off of the calculator as I think the decimal point might not be far enough to the left. Reason being running 3.73's with a 350/sm465 (still 1:1 in 3rd) 3.73's and 35" tires and I'd be lucky to get 12 running downhill with a tailwind.
Driving with 38's and 3.73's means it's going to take a while to get up to speed. Fuel economy will stink because you don't have enough mechanical leverage to get those big meats rolling. Yes larger tires give an overdrive effect, but if you spend so much to get them spinning the savings from the overdrive effect is negated.
For it to drive close to stock, jumping up to 4.56's or 4.88's or higher numerically would help get the big tires going. If it's still getting 10mpg or better after changing axle ratios consider yourself lucky.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 03-30-2011, 10:13 AM   #4
wiggins
wiggins's Avatar
Yeah I questioned the mpg's as well and know the guy is telling him more like 12 but he thinks if the carb was "cleaned" it could get 14(hell of a salesman). I have a 1/2 ton 2wd that only gets 12 mpg with a mostly stock 350/350 combo w 373 gears. I am getting all the info from my Brother in law second hand, did I mention he is 21. I am not big into aftermarket 4x4 stuff but I knew enough to know that it all didnt add up and that was not going to be a good daily driver. Its a pretty nice looking truck, but not for what he needs. But like I said he is 21 and he says he's going to get it anyway. He just wants to look cool, I think!
Old 04-01-2011, 07:03 AM   #5
vtblazer
vtblazer's Avatar
I'd be more worried about stopping those meats with the under-rated braking system on the 1/2 ton axles more than the fuel mileage I was gonna get.
vtblazer is offline   Reply With Quote
Old 04-07-2011, 03:21 PM   #6
liftlawssuck
liftlawssuck's Avatar
I have a 79 1/2 ton short bed with 1 ton axles running a 350 with sm465 and 38's. Gear ratio is 4.10. I would love to get 10 MPG out of it. No real way of knowing as my speedometer is way off. Nor do I want to know. But I do know is it ain't good. It is fun to ride 3rd gear though.
liftlawssuck is offline   Reply With Quote
Old 04-07-2011, 03:58 PM   #7
wiggins
wiggins's Avatar
Well he bought that truck and drove it 2 hours home, says he got 12 mpg. Not sure if he realizes that his odometer is not reading correct w those tires though so who really knows what he's gettn. If the lil punk ever drives it up here to see me I'll post some pics. My wife has seen it and she says its pretty nice looking.
Old 04-07-2011, 04:47 PM   #8
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Remember with big tires, your calculation would be low. You could find the actual MPG by cross multiplication...
stock tire circumference .......... calculated MPG
___________________...... = _____________
38" tire circumference ............. actual MPG (or X)
stock circ. * "X" = 38" tire circ. * calc. MPG
............"X" ........... = (38" tire circ. * calc. MPG)
............................... ______________________
............................... stock circ.
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 04-07-2011, 10:30 PM   #9
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yea I doubt he's getting that great of mpg haha! I would defiantly look into bigger axle swap or very least ugrade the brakes!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 04-07-2011, 10:48 PM   #10
wiggins
wiggins's Avatar
hey thats great info, I have never seen this, thanks.
Old 04-08-2011, 05:30 AM   #11
propanemudtruck
No problem. That calculation was a lot easier than keeping 1/2 ton axles in 1 piece with 38's!
-Kevin
Old 04-08-2011, 10:26 AM   #12
wiggins
wiggins's Avatar
Yeah I tried to tell him. I guess he will learn the hard way on this one. Thats fine though once he breaks it, I will get it from him bc he wont have the $ or the know how to fix it. lol
