Old 04-06-2011, 05:35 PM   #1
Miller92
Miller92's Avatar
Got a coil spring question for you guys
I got some coil spring spacers and when I went to put them on today I realized my springs didn't look right? I got the best pics I could, are these lowering springs or have they been heated up? Or did the 1/2 tons come stock with these?
Miller92 is offline   Reply With Quote
Old 04-06-2011, 05:39 PM   #2
67swb72klb
67swb72klb's Avatar
Re: Got a coil spring question for you guys
i cant see the pics ?
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 04-06-2011, 05:46 PM   #3
Miller92
Miller92's Avatar
Yea it might help if I upload them huh? lol my bad
Old 04-06-2011, 06:03 PM   #4
Stubnosebrock
Nope they are just fine. Stock springs im sure. I believe they are a multi rate spring. Someone correct me if im wrong on that. But your springs are fine
Stubnosebrock is offline   Reply With Quote
Old 04-06-2011, 06:20 PM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
No sir, those springs have met the heat from a torch....
I seen and heated plenty in my time !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 04-06-2011, 06:23 PM   #6
Stubnosebrock
Not trying the argue, But I can honestly say that every 60-66 coil spring rear truck I can remember seeing, the springs have looked like that. Im pretty sure mine haven't been heated and they have the same set of coils that are close just like the OP's
Old 04-06-2011, 06:27 PM   #7
Miller92
Miller92's Avatar
Well stock or not, you guys think I should put my spacers in these or try and find some others?
Old 04-06-2011, 06:28 PM   #8
lakeroadster
Agreed.
They have been heated. Once an individual coil touchs an adjacent coil it no longer has any "spring rate".
I'd go ahead and try the spacers but I am betting it will ride very rough though. Once you put in the spacer you will only have 1 wrap of coil acting as the entire spring, all the other wraps of coils are already collapsed.
lakeroadster is offline   Reply With Quote
Old 04-06-2011, 06:30 PM   #9
Stubnosebrock
What exactly do you mean by spacers? The things that go in between the coils to give the springs some lift?
Old 04-06-2011, 06:31 PM   #10
Miller92
Miller92's Avatar
Yes sir. I've got some coil spring spacers to raise the rear end up 2.5".
Old 04-06-2011, 06:33 PM   #11
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
First off coil spacers suck .... In this situation, to get them to do anything, you'd have to squeese them in between the collasped coils. Good luck with that one. Disconnect shock, and lift truck by the frame.
Originally Posted by lakeroadster View Post
Agreed.
They have been heated. Once the coils touch each other they no longer have any "spring rate".
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-06-2011, 06:33 PM   #12
Stubnosebrock
Well im beginning to think ive been wrong about the springs, but it cant hurt to try the spacers. Worst case scenario, they dont do what you want, and maybe a new set of stock springs will get you where you want.
Old 04-06-2011, 06:35 PM   #13
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
If you cant find some truck springs ... try some G-body ones.
Not sure what the height would be.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-06-2011, 06:39 PM   #14
Miller92
Miller92's Avatar
How would I lift it by the frame? I just thought the spacers would be best for me cause right now I'm still in high school and am low budget.
Old 04-06-2011, 06:41 PM   #15
Stubnosebrock
Hes saying to undo one side of your rear shocks to give you some spring travel and jack the truck up by the frame to stretch the springs out, and put the spacers in between two of the coils that are closed up
Old 04-06-2011, 06:45 PM   #16
lakeroadster
And you will never get a 2-1/2" spacer between the collapsed coils in the center. The only place the spacer will fit is either near the upper coils, or the lower coils.
And with only a couple coils really doing all the work the ride will be harsh.
How does the truck ride now, without the spacer?
Old 04-06-2011, 06:48 PM   #17
Miller92
Miller92's Avatar
Thanks for the info guys, I appreciate it a ton!
Old 04-06-2011, 08:28 PM   #18
PAPA KENT
PAPA KENT's Avatar
He has the (variable)rate springs under his truck,they were used on the heavy half tons and the c-20's.they have the 3 coils almost touching each other in the center versus the (normal) or standard coils.the heavier coils are also thicker by quite a bit over the standard rate springs,and much heavier to lift.i tried a set like those and they sit the same but are much stiffer.i have 2 pairs if anyone needs them.
PAPA KENT is offline   Reply With Quote
Old 04-06-2011, 08:28 PM   #19
Red65C10
Red65C10's Avatar
Those springs are "sprung" the coils are not designed to touch each other. If not a torch that truck was used for many years hauling something of significant weight to break em down like that. New ones are cheap, you need em for sure !
Billy
65 C10
............................... ____
................ ________-|___\____
.;.;;.:;:;.,;.|__(O)___|____/_(O)|
_______________________________
P.S. Send truck money !
Red65C10 is offline   Reply With Quote
Old 04-06-2011, 08:42 PM   #20
Stubnosebrock
I would have to agree. My truck has springs like this and I have seen others. I find it hard to believe they were all heated up. I thought I was right on the variable rate thing.
Old 04-06-2011, 08:48 PM   #21
kalirodding
CLASSIX Truck Club
kalirodding's Avatar
I have cut the springs on 4 different trucks, and all the springs have looked like that. Definitely not heated but could be collapsed. These trucks are old.
kalirodding is offline   Reply With Quote
Old 04-06-2011, 09:01 PM   #22
PAPA KENT
PAPA KENT's Avatar
Here are some pictures of the springs that miller has now there is a larger gap in these between the center coils but these of course are unladen being out of the truck.there was 1/8" or just a hair more of clearance between the center coils when they were mounted.check out the thickness of the coils.
Old 04-06-2011, 11:43 PM   #23
yelmer
my c 20 has these springs but the do not touch . you cannot get these springs from any spring company they say the sell them, but they are completely different . not the tight coil setup
yelmer is offline   Reply With Quote
Old 04-07-2011, 12:28 AM   #24
PAPA KENT
PAPA KENT's Avatar
yes your right, 20-30 years ago you would see these quite a bit when 3/4 tons were seen daily.miller92's springs have sagged and compressed over the years.when i bought my 62 they had standard 1/2 t springs that someone did a piss poor job of heating and lowering so i put a pair of the heavy duty springs under it and it was a little to stiff for me anymore so i opted for a (light duty) standard set.i just figured i would keep these around in case i change my mind.
Old 04-07-2011, 02:29 PM   #25
Miller92
Miller92's Avatar
Thanks for all the info guys, yall have been a big help!
I'm currently trying to find some springs that went under the 2wd 3/4 ton pickups and hopefully that'll raise it a bit. I knew the truck looked lower than normal but never did check it out. Now I know why. The front is a lil lower than I like but I can't change them myself so those will have to wait a while. Only 3/4 ton springs I've found so far are in LMC for $70. Didn't seem too bad to me but imma try to find some for cheaper first. You guys know what year springs will work for these pickups?
