04-06-2011, 07:00 PM | #1 |
Any vendors do body bolts?
Do any vendors offer just the 2wd blazer body bolts as a kit? I bought one of those body mount kits and cheaped out on hardware thinking i could easily find it. Unfortunately, these things are just not easy to find. I tried one of those trailer places but nothing long enough. Can anyone maybe think of somewhere else to look?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
04-06-2011, 10:07 PM | #2 |
Re: Any vendors do body bolts?
LMC or probably any of the vendors. I just bought a set of bolts and the necessary washers/nuts to go with a poly body mount set I got from Energy Suspension.
04-06-2011, 11:06 PM | #3 |
Problem solved. My local home depot had all the bolts, washers, locknuts, and posi-lock nuts i needed.
04-07-2011, 01:31 AM | #4 |
Collector of Projects
I hope they are at least grade 5, if not grade 8.... think about the force needed to keep the body mounted to the frame... there have been discussions about this....
04-07-2011, 07:07 AM | #5 |
I just bought (within the past three weeks) and installed an LMC rubber body mount kit on my Blazer and it had the correct carriage bolts. Mount position #2 (front floor area) does use hex head from the factory.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
04-07-2011, 12:14 PM | #6 | |
Stalker Nate
Typically Carraige bolts are made in Grade 2 strength, unless otherwise noted on them. I used to sell industrial supplies and many people thought Carraige bolts and hex head bolts were all the same strength. They aren't and there's no need for a grade 8 bolt from body to chassis. There are certain strengths you look at in bolts for certain reasons, and how the body is mounted I don't see a need for grade 8 bolts. I tend to put grade 8 in most everything I do just because, and not always because it's required.
Nate
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
04-07-2011, 08:27 PM | #7 |
My bad, forgot i bought the ORD 1" body lift and had to use their bolts
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4 Work in Progress http://67-72chevytrucks.com/vboard/s...d.php?t=291482 ****SOLD!!!!!**** 1965 GMC 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=294727 |
04-07-2011, 11:26 PM | #8 |
I just received all the body mount kit hardware from LMC. Everything seems as it should.
TruckMan - how do you like the body lift? Are your bumpers hanging 1" low now? |
04-09-2011, 12:38 AM | #9 |
I like it, didnt plan on needing it but i mounted my NV4500 about 1/2" too high. only con is the bolts all being standard hex heads and not carriage bolts. the bumbers are an inch low, but its not really noticable on the rear and the only noticable part on the front is that the gap between the grille and the bumper is almost non existent
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4 Work in Progress http://67-72chevytrucks.com/vboard/s...d.php?t=291482 ****SOLD!!!!!**** 1965 GMC 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=294727 Last edited by 72truckman; 04-09-2011 at 12:38 AM. |
04-09-2011, 01:54 AM | #10 | |
