Old 04-12-2011, 08:12 PM   #1
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
I already have the 5.3 installed. However,..
I have a very nice 6.0 sitting in the garage. Can I use the same computer for the new 6.0? everything I have seen says yes. However, I figure I would ask.
Seems to me like a no brainer, everything should bolt up with no issues.
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 04-12-2011, 09:08 PM   #2
85burb
85burb's Avatar
Re: I already have the 5.3 installed. However,..
I think you will just have to have it reprogramed to know it is a 6.0. All the sensors should be the same.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 04-12-2011, 09:43 PM   #3
HavinSomeFun
the only thing changins is cubic inches... Same tranny, same intake and etc... only real change is a bigger cam than the 5.3.
Old 04-12-2011, 10:27 PM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
The tune in the computer will need to be changed. What years are the motors? Only problem you may run into is the 24x and 58x reluctor rings if dealing with 07+engines.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-13-2011, 07:01 AM   #5
HavinSomeFun
5.3 is an 02 and the 6.0 is an 05.. Yes, will have to tune for the new setup. The cam in the 6.0 is somewhat larger than the 5.3. However, I think the current tune will let it run OK.
Old 04-13-2011, 08:44 AM   #6
Shon
Just change the stuff in the PCM for 6.0 stuff.....
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 04-13-2011, 08:29 PM   #7
HavinSomeFun
you mean for the cam or does the computer operate different for the 6.0? Besides the cam I figured the only real difference was the cubic inches...
Old 04-13-2011, 09:04 PM   #8
Shon
THere are several ways to do it. but one of the key things to do is to change the displacement in the PCM from 5.3 to 6.0, this goes into many calculations for the Air and Fuel.
if stock motors then the tuner would probably just take the VE and MAF tables from a stock file and copy over or if they have tuned them successfully they would pull from that db and put in those changes.
Old 04-13-2011, 09:23 PM   #9
HavinSomeFun
got it!
Old 04-13-2011, 09:26 PM   #10
HavinSomeFun
SHON, you tune don't you?
Old 04-13-2011, 09:30 PM   #11
Shon
I do.
Old 04-13-2011, 09:35 PM   #12
HavinSomeFun
So if I have this cam, Custom comp Cam Hydraulic roller
Camshaft Specs: Valve Lift (1.7) Duration@.006 Duration@.050 CL 114
int: .596" 303º 250º
ex: .596" 299º 246º
2500 stall, 3:73 gears and 28.5 inch tall tires, headers and free flowing Filter... You could get close on the tune?
Old 04-13-2011, 09:40 PM   #13
Shon
ex: .596" 299º 246º
am I reading that right a reverse split cam of 250/246 with .596 lift on a 114?
a cam that large really needs to be tuned in person but I will give it a shot...what trans?
Old 04-13-2011, 09:42 PM   #14
HavinSomeFun
Yes, a big cam, what can I say, I got a good deal on it.... still running a built 4l60e
Old 04-13-2011, 09:44 PM   #15
HavinSomeFun
All this power and I still drive it like an old lady... except sometimes I get the itch to release a little aggresion. The 5.3 with the cam, headers and OK tune runs like crazy already and sounds awsome. I just figured a 6.0 would be better therapy.
