Old 04-15-2011, 12:06 PM   #1
Petie724x4
4x4 specific rad?
In a jam with a blown stock rad, and have a collection of good rads from other random half tons, but none with the 45degree lower rad nipple. Quickly realizing that is the slight difference. Anyone run into this, or have a solution?
Not trying to be cheap or disrespect my truck by jamming in something that "shold hold together for now", but up here in Canada ordering a new rad has to be shipped from afar and major $$.
Alternative rads? different lower rad hoses?
Thanx
Petie724x4 is offline   Reply With Quote
Old 04-15-2011, 02:02 PM   #2
Gene
Gene's Avatar
Re: 4x4 specific rad?
I am running the same radiator in my 4x4 that I ran in my 2wd? The bottom one angles up but I would say its more of a 20 degree angle? I dont see why you cant just run a different hose?
Gene is offline   Reply With Quote
Old 04-15-2011, 03:41 PM   #3
pumpkin
pumpkin's Avatar
The quickest solution is to get your old rad recored at a rad shop.
pumpkin is offline   Reply With Quote
Old 04-15-2011, 10:17 PM   #4
Livrat
Member #1049
Livrat's Avatar
Your could take the blown radiator and a known good one of the same dimensions (without the correct lower nipple) to a radiator shop and have them switched, They are just soldered on.
Or if your familiar with acid core solder and a propane torch, switch them your self
Livrat is offline   Reply With Quote
Old 04-16-2011, 11:24 AM   #5
mmmBoost
My radiator has straight lower and I haven't had any problems with it.
Always remember those that had your back
Never forget those that turned it
Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt,
Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner
mmmBoost is offline   Reply With Quote
