04-15-2011, 09:58 PM | #1 |
Tall and skinny tires for '68 C10 Longbed
Hi All...
I've been lurking the site for about 6 months and finally joined last month when I bought a 1968 C10 (2WD). I've been using the search function for most of my questions, and I've found and learned quite a bit, thanks! Most of the trucks I see with suspension/tire mods are lowered. Call me crazy, but I wanna go up! Not a lot, but more in line with the trucks I remember as a kid. Tall skinny tires snow tires and dog dish caps on steelies...some of you older guys (like me) know what I mean... So I'm hoping some of you can tell me: -What are the tallest tires that will fit under the stock fenders without rubbing? 235/85-16? 215/85-16? 33/9.50-15? -Where can I find 16" 6 lug steelie rims? -Any of you running a tall skinny combo on a stock suspension? Pics? Specs? -Is a 5 lug conversion required to get this done or are the rims/parts available for the 6 lug setup? I rolled some tires next to the truck today to get some ideas. The current tires are 235/75-R15s on the stock suspension. They look way too small to me, but the 235/85s look great. No issues in the rear, but the front? Dunno...but a 1 inch lift would probably do it. Coupla pics...: Looking for some guidance here...thanks in advance! Bruce Last edited by Hardball; 04-15-2011 at 10:05 PM. Reason: grammar |
04-15-2011, 10:03 PM | #2 |
Who's got steelies?
Re: Tall and skinny tires for '68 C10 Longbed
First of all, let me say welcome from Oklahoma! I like your truck and the way you are thinking. The 'stock' look on these trucks is just timeless! I don't know about 6-lug 16" rims. Someone will chime in. OE would have been 16.5 I think.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
04-15-2011, 10:19 PM | #3 |
Thanks for the welcome, OG70...
Here's a pic I saved while searching for clues, to give you an idea of what I'm going for: This is more "offroad" than I want, but the tires look to be as big as they can be for a 2WD C10. |
04-15-2011, 10:30 PM | #4 |
I just put 31x10.5x15's on my 70. Fit just fine and they look good. I will get some pics this weekend for you if you are interested.
04-15-2011, 10:40 PM | #5 |
Hey, I'm in the same mind set at you hardbll. Some day I'd like to put some tall skinny repro bias-plys on mine for that really true stock look. I'm always looking for tires that might look good on my truck.
I think 16.5 inch rims were an option on our 68' half tons. I'll have to check my records when I get back to my house. I don't know if you can even buy 16.5 inch truck tires any more. I'd imagine they are not cheap.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
04-15-2011, 11:32 PM | #6 |
so easy a caveman can do it...
subscribed....I'm probably going to do some mud terrains on mine.
04-16-2011, 12:08 AM | #7 |
04-16-2011, 11:27 AM | #8 |
33" tire will fit with stock, non-sqaushed springs and factory back spacing. It is tight, and some tread designs may rub a bit on tight turns or big bumps, but very do-able.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
04-16-2011, 01:25 PM | #9 |
Welcome! Yes I also miss the way most 67-72 pickups looked in the 70's and 80's. Today most have been altered one way or another.1968 Chevy 1/2 tons did have larger wheel options from the factory. The tall skinny look would be the 16" and 17.5" wheels. The 16" are hard to find and the 17.5" are very hard to find, since most people bought the vehicle with the standard 15" wheels. Goverment and fleets would generally opt for the 16" wheel and 4 wheel drive buyers would opt for the 17.5" wheel for maximum ground clearance. Your best bet for the tall skinny look would be trying to find some period 6 lug 16" wheels(will require searching) and use 215/85-16 tires.
04-16-2011, 06:50 PM | #10 |
and on your "new" "old" truck.
She sure is pretty. Do you have any pictures of the interior and engine? Keith |
04-19-2011, 10:13 AM | #11 |
Thanks for the warm welcome and the info...
Here's a few more pics as requested. I'm still looking for rim info. Leaning towards the 235/85-16s if I can find the right rims. Has anyone here tried the Toyota 16" rims? Do they require spacers or is the offset ok as is? Also, do the C20 springs fit the C10? I'm trying to get a bit of lift and stiffen the suspension as well. Last edited by Hardball; 04-19-2011 at 10:45 AM. Reason: Add question... |
04-19-2011, 10:45 AM | #12 |
Mentioning spacers will get a negative feed back from most. Although I believe those running the Boss type 17's and such have to run spacers to fit our model of trucks. Spacer prices if you check around can get expensive from what I have seen.
I like the present ralley wheel look you have and would simply use drop springs 2 in front and 3 in the rear. This way spending much less, accomplishing the same effect for only around $200 or so. Nice truck by the way. Welcome ..
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
04-19-2011, 10:52 AM | #13 | |
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
04-22-2011, 12:54 AM | #14 |
nice ride , love the idea of tall skinny's even if mine is just another lowered shortbox. Watch out on the 235/85's , i have run them for years on my 99 suburban workhorse , they ride like crap compared to a good 15" radial ,you just might want to be ready for the poor ride quality.
04-22-2011, 01:30 AM | #15 |
04-22-2011, 05:32 AM | #16 |
The Niner
It all depends on the brand. You get a nice set of Michelins in that size and you'll get a really good ride.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
04-22-2011, 08:44 AM | #17 |
Sweet truck.
04-22-2011, 08:57 AM | #18 |
I have a set of Cooper Discoverer 285/17's on mine with factory 05 Tahoe wheels, I had to use 1 1/2" block spacers to bring the tires out so they would not rub, the front would have been fine without the spacers but the back would rub the inside fenderwell since those rims are set for all disc brakes but they fit fine and work well
04-22-2011, 09:59 AM | #19 | |
Chemist under the hood...
Thanks!
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
04-24-2011, 01:39 AM | #20 |
Thanks...
The lower alternator bracket mounts to the water pump bolt and the upper mounts to the intake manifold. Pretty good setup... |
12-07-2011, 03:53 PM | #21 |
Junior Member
you get 235 85's yet?
frontstreetcycle on Instagram |
12-07-2011, 04:27 PM | #22 |
235/85 are basically same as the 16-7.50s that came on 3/4 tons. Thats what I am going to run on my steelies. Tall and narrow. Same thing that most duallys have stock nowadays.
Daily-94 K2500 350 5spd extended cab longbox Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack. Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881 My 01 TA and 88 Formula hide in the garage. :-) |
12-07-2011, 04:41 PM | #23 |
Not yet, Craig. Dug into the suspension first, PO did a torch drop on the coils so I decided to sort out the springs, shocks, bushings, etc before wheels and tires. As it was, the suspension wouldn't clear the 235/85s Picked up some early/correct hubcaps for the 15" rims I have, might try the 265/75 15s. Still on the lookout for some 16" steelies. 6 lug, of course... |
12-07-2011, 08:51 PM | #24 |
Currently Blazerless
I know this isnt what your looking for but couldnt resist, my 68 is a K-10 but other than that our trucks could be sisters! I'm running a very narrow 33" on 6" steel wheels..dont even remember the brand without going out and looking.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
12-08-2011, 12:54 AM | #25 | |
looking good.run 255-70-15 on the rallys.fills in fender wells nicely.i'm going to have to put new tires on this spring,i'm going to try 275's to see if they fit. if anyone is running 275's chime in. |
Tags |
tall tires |
