Old 04-16-2011, 10:40 PM   #1
andyh1956
nv 4500 to 208
hey guys. i have a '94 4x4 dually that i am removing the engine to install in an m1008. 1008s have turbo 400 & 208s but the dually has a 4500. of course the dually transfer is a left hand drive & the 1008 is a right hand drive. my question is can the 1008 208 be mated to the dually 4500? sure would be nice to have o/d in that truck, especially with 4.56 axles. thanks!
andy
andyh1956 is offline   Reply With Quote
Old 04-16-2011, 10:52 PM   #2
gearhead1985
Re: nv 4500 to 208
try it but if worse comes to worse you can swap parts between the two 208's to make the m fit cause the guts are the same
gearhead1985 is offline   Reply With Quote
Old 04-17-2011, 07:49 AM   #3
b454rat
Re: nv 4500 to 208
IIRC unbolt the B/W from the dually and bolt on the 208. It will bolt right up.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 04-17-2011, 11:15 AM   #4
andyh1956
Re: nv 4500 to 208
thanks a lot! i also have a 4dr square body that i may 4wd & this would be better than the 205 / 465 that i was gonna use in it, but the 4dr may go on an m35 roller instead. wait & watch!
andy
