04-22-2011, 11:19 AM | #1 |
Steering Column Bearing
I am having trouble find a replacement bearing for my steering column. I feel sure some of you have had to replace it. Suggestions?
73 C-10 Cheyenne Super 454 60 Impala LS powered 16 Camaro 2SS 6speed 12 Ultra Classic 71 Vega Wagon V8 4 speed |
04-22-2011, 11:41 AM | #2 |
Re: Steering Column Bearing
for bearings that i cant find by specific application i go to graingers and purchase by measurements// my dust collector for blast cabinet needed a bearing only replacement from manuracturer was the whole darn motor, for about $5 withshipping i got the bearing from graingers and its back in business
04-22-2011, 12:23 PM | #3 |
I would like to know a lil about this too..
'72 Nova '71 C10 '63 VW Beetle ...............................____ .................________-|___\____ ..;.;;.:;:;.,;.|__(O)___|____/_(O)| _______________________________________ |
04-22-2011, 12:57 PM | #4 |
Are you talking about the lower or the upper?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
04-22-2011, 12:58 PM | #5 |
Did a quick Google search and Brothers shows both the upper and the lower.
04-22-2011, 01:19 PM | #6 |
Active Member
As Cdowns mentoned: If you're in a hurry most bearings have a number and if you have a bearing place listed in the yellow pages take the bearing with you and see if they can match it. I have replaced several in the past that way.
04-22-2011, 04:32 PM | #7 |
I dont think you will find these brgs at a industrial supply store. They are specific to these columns. The lower one comes with a kit that includes the spring & seat. I have the GM part numbers at the shop & can look them up tomorrow. Many of the specialty supply parts places have them.
George |
04-22-2011, 05:03 PM | #8 | |
Classic Parts has both the upper and lower bearings: http://www.classicparts.com/Steering...oducts/307/1/0 American Classics has them too... http://www.classictruck.com/category...column+bearing Some vendors offer a sleeve type bearing for the lower bearing. Since the steering column isn't water tight at the base, water gets in and wreaks havoc with the OEM roller bearing. I went with the sleeve bearing from American Classics, something you might want to consider. Another thing to look at: If the lower bearing has failed the steering column shaft may be worn. On my truck it was severely worn and I welded and machined it down. How it looked at disassembly How it looked after repair: Hope that helps! John Pictures of bearings below are: Lower Sleeve Type Bearing, Lower Roller Type Bearing Kit, Upper Bearing (Roller Type) Last edited by lakeroadster; 04-22-2011 at 06:08 PM. |
04-01-2014, 11:24 PM | #9 |
Where do you use that lower sleeve type bearing ?
1968 C10, 250, L6 4spd OTF, Fleetside Upgrades: Power Steering .......................____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
