Old 05-11-2011, 05:02 PM   #1
Heavy Evy
born to lose
Heavy Evy's Avatar
Anybody gotten exhaust work done there burb recently?
I got a quote for $450 to dual out my burb with turbo mufflers. I hate the stock single exhaust on my burb its too restrictive and I want a little more performance out of the ole girl. Anybody think this price is high? Our burbs are huge so it makes for alot of tubing about 14 feet haha. Maybe I should just do it myself.
_____________________
'67 Chevy Belair Wagon 283 Powerglide
'68 Chevy II Nova 2 door 350 TH400 Sold!!
'71 Chevy C20 350 TH350
'71 Chevy C10 Burb 350 TH350 stolen totalled gone....
Burb Build
http://67-72chevytrucks.com/vboard/s...d.php?t=475155
Nova Build
http://67-72chevytrucks.com/vboard/s...d.php?t=498979
Wagon Build
http://67-72chevytrucks.com/vboard/s...d.php?t=543052
Not giving a truck.
Heavy Evy is offline   Reply With Quote
Old 05-11-2011, 06:00 PM   #2
Mulk
Mulk's Avatar
Re: Anybody gotten exhaust work done there burb recently?
Sounds about right with the mufflers. I just got quoted $330 to have everything re-routed between frame rails (Installing 'bags in next few weeks). That includes cutting/reinforcing holes in crossmember. But utilizing my current Flow Masters.
Eric
'68 C20 Suburban, Bagged with Suicide 3rd Door, and Loaded with a 396 - Under Construction
http://67-72chevytrucks.com/vboard/s...d.php?t=403690
Mulk is offline   Reply With Quote
Old 05-12-2011, 11:45 PM   #3
Brewski*
Brewski*'s Avatar
My local guy did mine for around 250 but his prices are considerably lower than most.
Brewski* is offline   Reply With Quote
Old 05-12-2011, 11:48 PM   #4
dougo
dougo's Avatar
I think that would cost about the same where I live, +/- $50.00.
Doug
'72 GMC K2500 Suburban 4x4
dougo is offline   Reply With Quote
Old 05-13-2011, 12:20 AM   #5
AzDon
AzDon's Avatar
If you are going out behind the axle, there is a fair amount of work involved.....If I was havin it done, I would turn it out directly behind the front suspension and run it along the outside of the frame and turn out ahead of the rear wheels. I like bullet straight thru glasspacks like cherry bombs.
AzDon is offline   Reply With Quote
Old 05-13-2011, 10:06 PM   #6
rockc
AZDon do you have pic's of what you want? I am planning on redoing mine on my 72 sub and was thinking about running them about 6" to 12" in front of rear wheels at a 45 degree angle.
72 chevy 3/4 ton 4X4
rockc is offline   Reply With Quote
Old 05-14-2011, 04:07 PM   #7
AzDon
AzDon's Avatar
Mine had existing duals with glasspacks that hang below the frame and go up and over the rear axle inboard of the chassis and out the back. My current setup is vulnerable to speedbumps and prevent further lowering. I'll probably replace eventually.
IMO, out the back should NEVER be done on a wagon, panel, or van unless you really like the smell of exhaust.
The design I mentioned is completely tucked above the bottom of the chassis. The pipes pass thru the raised gap behind the front suspension and run along the outside of the frame and you can turn out anywhere and at any angle you choose. I've always wanted to slip angle-cut truck stacks over the bullet glasspacks and turn out a 45 degree angle. Logically, the turnout should be behind the last openable window.
