Old 05-15-2011, 03:41 PM   #1
roofingbloke
just finished my front crossmember section
here are some pics, 1.5"
roofingbloke is offline   Reply With Quote
Old 05-15-2011, 04:12 PM   #2
kyle87
Re: just finished my front crossmember section
wow! cleanest one i'v ever seen. awesome welds
kyle87 is offline   Reply With Quote
Old 05-15-2011, 05:39 PM   #3
68chevyLQ4
68chevyLQ4's Avatar
That looks really good. Nice work.
68 Chevy C-10. swb fleetside. 6.0 4L80E swap.
http://67-72chevytrucks.com/vboard/s...d.php?t=460877
68chevyLQ4 is offline   Reply With Quote
Old 05-15-2011, 07:20 PM   #4
broey
Square
broey's Avatar
pretty awesome man!
Squarebody Syndicate
broey is offline   Reply With Quote
Old 05-15-2011, 11:35 PM   #5
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
Good looking welds!!! Let's see what kinda truck it's going on
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 05-15-2011, 11:43 PM   #6
ol_skool_chevy
ol_skool_chevy's Avatar
Wow........I agree Looks Great. I might be wrong, I dont know everything but that looks like alot of work for only 1 1/2 inch lower. whats the Gain? Im open to learning more..
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 05-16-2011, 01:32 AM   #7
roofingbloke
In my opinion its either section the crossmember or do a Z in the chassis, i think this is an easier option to gain 1.5".
This was my last choice before spending lots of money on a aftermarket crossmember, i will allways choose self build over purchased items, thatway i gain more knoledge,
Old 05-16-2011, 08:26 AM   #8
csa daddy
csa daddy's Avatar
combined with a z of 3.5 this will net you 5 inches of drop. also depending on which body it is a z is required, i think in order to lay a square body on its frame in order to clear lower control arms. but to lay the pinch it will need a stock floor body drop or some kind of body drop to lay any kind of body
csa daddy is offline   Reply With Quote
Old 05-16-2011, 09:46 AM   #9
ol_skool_chevy
[B]I agree with your "[i will always choose self build over purchased items, that way i gain more knowledge," comment.
To me that might be one of the smarter comments I have seen here. Buying is not building. that's why the Ol' Skool Chevy Name..I build the way we did in the Old days Nothing new.
I guess my only thinking on your cross member was "what's the gain" but if your going seriously low I guess anyplace you gain ground clearance is a plus.
Again GREAT WORLK...............
/B]
Mark with Chalk
Cut with a torch
Old 05-16-2011, 12:00 PM   #10
Scot_Douglas
Scot_Douglas's Avatar
Great job!
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 05-16-2011, 12:14 PM   #11
charx2
charx2's Avatar
Wow, I wish I could weld like that!
My 67 c10 Thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=409192
charx2 is offline   Reply With Quote
Old 05-16-2011, 01:10 PM   #12
broey
Square
broey's Avatar
The 1.5 out of the cross member is still going to put the control arms and cross member on the ground. But it will help the truck sit a little more evenly when laid out. On my truck the crossmember needed a lot more work than a pancake to lay pinch.
Old 05-16-2011, 10:07 PM   #13
Scot_Douglas
This is with 2" out of mine with 2.5" drop spindles. (and temporary motorcycle springs that let is sit another 2" lower)
28.5" tall tires.
1966 C10
Build 'Fread
Old 05-16-2011, 10:55 PM   #14
ol_skool_chevy
[QUOTE=Scot_Douglas;4684271]This is with 2" out of mine with 2.5" drop spindles. (and temporary motorcycle springs that let is sit another 2" lower)
28.5" tall tires.
[/QUOTE
wheres your tie rod????????
Mark with Chalk
Cut with a torch
Old 05-17-2011, 07:23 AM   #15
Scot_Douglas
It's in there somewhere.
1966 C10
Build 'Fread
Old 05-17-2011, 09:05 AM   #16
csa daddy
csa daddy's Avatar
how about a little closer an more personal pic of your rack set up i like that. it looks awesome is that going to be ride height
Old 05-17-2011, 11:16 AM   #17
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I'm more interested in whats going on out back, I've seen a rack and pinion before.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 05-17-2011, 11:34 AM   #18
ol_skool_chevy
I see now at that angle. No tie rod, you used rack...nice
Mark with Chalk
Cut with a torch
Old 05-17-2011, 12:18 PM   #19
Scot_Douglas
There should be plenty in my build thread - and right now, I'm sitting about 2" lower than my targeted ride height.
Sorry for the thread hijack, Bloke!
1966 C10
Build 'Fread
Old 05-17-2011, 01:45 PM   #20
roofingbloke
Hi Scot douglas, ? what headers are they,
Old 05-17-2011, 06:04 PM   #21
Scot_Douglas
I'm sorry to say that I can't find an application. I paid $5 for them because someone boogered on some steel pipe in place of the connectors.
They are Edelbrock, and the tag has the numbers 6067 / 7967. I just tried a quick search and can't find any info for them. On Edelbrock's webpage, they look a lot like the TES headers but I can't find a match for the tag/numbers I found.
1966 C10
Build 'Fread
Old 05-19-2011, 05:20 PM   #22
roofingbloke
I have done a test fit, the steering arms hit the crossmember, i am thinking that the power steering box is an aftermarket item and may have been fitted to far back,
Old 05-19-2011, 05:34 PM   #23
smashingchuck
Nope, nothing is wrong , that's what happens when you go 1.5".
78 Build Thread
4Runner Build
Old 05-19-2011, 05:41 PM   #24
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Mine required some grinding at 1.25" so I can imagine you'll need some at 1.5".
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 05-19-2011, 06:03 PM   #25
smashingchuck
The proper thing to do is raise the sttering the same amount.
78 Build Thread
4Runner Build
