72 Blazer
I am thinking about upgrading my suspension(new springs/4'' lift) on my 72 Blazer, any suggestions, recommendations?
Preserving American History one truck at a time. |
Re: 72 Blazer
What are you going to be using the Blazer for?
Camping and fireroads or heavy off-road trail blazin? ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
Re: 72 Blazer
nothing to extreme mild off road, its to nice of a Blazer to tear up but my springs are starting to sag a little and its not siitting level anymore. I want it to handle good going down the road and be ok off road. I ve been happy with the factory springs
Re: 72 Blazer
with out pics, my mind is a blank
![]() ![]() nice nomad, one of my alltime fav. vehicules, rite behind a '67 BB vette
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-24-2011 at 02:08 PM. |
Re: 72 Blazer
i might trade that Nomad for that particular vette' but I would have to think really hard about it, heres a pic
added for a my 56' Nomad as well for your viewing pleasure, lol
Re: 72 Blazer
VERY NICE on both fronts...thank you for the viewing pleasure!
It doesn't look that low in the rear, but you are sitting on an incline, how about a 1" zero rate with longer u-bolts. Lots of guys can help you out with their experiences... Welcome aboard!
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Re: 72 Blazer
its not really all that low front to back, it leans to the driver side by about 2'' or so. Never really noticed but I took that square body rear bumper off and put an original back on and that told the story. It was very crooked so I put the other bumper back on which has more adjustment in the brackets until I fix my lean.
Re: 72 Blazer
body mount bushings, rusted body brackets, broken leaf in a spring, bent frame,bent bumper brackets, or all of the above, ...just guesses. That thing looks to nice to have any of the serious problems listed above
what would you guess the Nomad would be worth??
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-24-2011 at 11:04 PM. |
Re: 72 Blazer
With that size tire, I'd probably go with a 2" lift.
Re: 72 Blazer
Looks like it has a small lift now... lower side to side seems like a broken leaf or a bushing issue????? Great looking rides by the way.
Re: 72 Blazer
Thanks guys! I am alos going to replace the body bushings which may be al the problem is as far as the lean. The current lift is a basic spring over using the factory springs w a 3'' piece of I' beam cut to fit on top of the axle as a block. It works fine but its not that smooth going down the road which may be my springs. I have talked to a local shop that does lifts and he said he would go w a 4'' lift (would sit about an inch higher) and get the axels back on the top of the springs. he said its afer and most importantly it would ride better. also I would need no block n the rear the lift would be all springs. It is pretty nice Blazer. It is at 110,000 original miles on all original running gear right now.Its had one paint job about 3yrs ago and this make shift lift, and some modern front buckets(still have the originals), other than that all original.
That Nomad would be worth about 60K but thats if it were for sale, lol
Re: 72 Blazer
If you go with the spring lift, have some custom springs made to meet your needs. Dont buy the over the counter ones. I just had springs made for my truck from ALCAN spring and I really like them.
#13 |
Re: 72 Blazer
Didn't say it was already lifted.
#14 |
Re: 72 Blazer
Thanks guys I have decided to go w a 4'' and just the stock size body bushings. I'll post some pics maybe next week or so.
#15 |
Re: 72 Blazer
So you basically have blocks front and rear? That's pretty dangerous (unsafe) for the front. good thing they're coming out!
#16 |
toys'r'us
Re: 72 Blazer
The leaf springs go on top of the axle tube from the factory and in all bolt on lift kits
71 jimmy bone stock 350 sm465 33x12.5 rallies 79 caprice landau full load crate350 th350 lowered 20"wires 00 f150 reg cab sb 4x4 5.4L |
#17 |
Collector of Projects
Re: 72 Blazer
goto diy4x.com and get the shackle flip to eliminate the rear block and use style stock springs and keep a decent ride. lift springs ride stiff. If you do buy front lift springs, spend the extra money and get thinner flexible springs for a better ride as well.
http://diy4x.com/cart/index.php?rout...product_id=112 Last edited by mcmlxix; 05-26-2011 at 06:04 AM. |
#18 |
Re: 72 Blazer
Nope just on the rear but I dont like em anywhere if I have a choice. Blazer was already set up this way when I got it, slowly fixing things.
#19 |
Re: 72 Blazer
Well that would explain the fron they are already on top w/o a block. This is my 1st Chevy 4x4 all my other 4wd stuff is IHC, mostly scouts, and the springs on them are all mounted underneath the axle from the factory front and back.
#20 |
![]() Join Date: Jul 2010
Re: 72 Blazer
wiggins you didnt by chance buy that k5 from a guy named gary hodges did you ?
#21 |
Re: 72 Blazer
Cant remember, Ill have to check. he was from Arkansas though. He had just been transfered to Tx w his job and Had just got this Blazer back from the body shop in Ak. I bought it from him unfinished w loads of spare parts. Slowly fixin her up.
#22 |
Re: 72 Blazer
I would about bet anything thats the guy . Cant remember for sure if that was his name or not but i know a real close friend of the last owner and i knew soon as i saw that blazer i about passed out ! You lucky dog i saw that blazer for years sit by my uncles house and always thought man i wish i had that k5 and would walk over and crawl around it and wish . At the time it looked like it does in your pics but the inside was not finished and i think it didnt have any of the seals on the glass but looked like alot of the seals and stuff were laying in the floor. I always wished i could buy it but didnt have the funds one day i had my friend call his friend and price it just so i would stop wondering what it would take to buy it . About a year or so later i was gonna be able to get the cash so i got his friends and was about to plan a trip to texas and called him but i was to late . Just wanted so say thats one nice 1st gen . And im glad i finally got to see it again . Good luck with fixing her up
#23 |
Re: 72 Blazer
Dude I have used and will only use Alcan springs for my projects. Never have had any issue, they will build a spring to your specs, ie: weight length, lift, etc. I know guys that use them in almost all application. Look em up they was about the same price as anywhere else. Only they are 40 minutes away and allow me to save shipping cost.
The shackle reversal is ok, but if I remember correctly it rolls the axle forward a bit and may cause issue when trying to stuff a larger tire.
Confidence is the feeling we have before we fully comprehend the situation Last edited by elks; 05-26-2011 at 06:44 PM. |
#24 |
Re: 72 Blazer
He could get the flip and have Alcan build stock height rear springs with the center pins moved back 1" to recenter the axle.
I have Alcan springs and so far they are great - still building the chassis but so far so good. Last edited by SeventyOne; 05-26-2011 at 09:39 PM. |
#25 |
Re: 72 Blazer
My 2 cents...Take what ya like and leave the rest.
Deavers or Alcan for custom made springs. Skyjacker Softrides for ready made. Springs @ all four corners. Steering Stabilizer ORD Greaseable Bolt/Shackles Rubber Body Mounts Bilstein Shocks I just lifted mine using a set 4" Skyjacker Softride springs, It rides better than it did stock...and is pretty comfortable ..I'm happy with them. (I got them at cost so went that route). I'd go with custom springs if you can wait the 3-5 weeks though. I changed my shocks to Bilsteins and love them, Replaced old worn out body mounts to Rubber Body Mounts (I had the same lean as you have and swaping the mounts and springs corrected it). I'm going to put the ORD Greaseable Bolt/Shackles in soon as well. I'm running 33" x 12.5" x 15 MTZ's
![]() Last edited by bigeasycigars; 05-27-2011 at 02:40 AM. |
