Old 05-28-2011, 11:35 PM   #1
tk-mpl
tk-mpl's Avatar
2007 Battery load module
I just noticed that my alt is not charging... It had the battery load module thing on the battery cable originally. I did not have that to put it in. Will the PCM not just turn the alt on when it sees a drop in voltage?? Can you tune the PCM to charge it normally with out this module??
Thanx
Trevor
1968 short box stepside.
2007 5.3L 4L60, tuned w/EFI Live
2005 Silverado bucket seats.
Dominator 2600's all around.
Porterbuilt tubular control arms.
Magnaflow 3" dual exhaust.
tk-mpl is offline   Reply With Quote
Old 05-29-2011, 12:05 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: 2007 Battery load module
67C10BUB is the only person I can think of that has used it. Maybe he knows. Good luck
http://67-72chevytrucks.com/vboard/s...=421326&page=4
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 05-29-2011, 09:43 PM   #3
BustedTruck
BustedTruck's Avatar
First off what is your engine out of? Typicaly if the battery current sensor fails the pcm or ecm commands a default voltage of approximately 14volts. I have an 05 tahoe engine & left it off with no problems. The battery current sensor is connected to the pcm on my 05 tahoe & depending on what your engine is out of, may be connected to the bcm. You should be able to just leave it off. I would double check your connections first.
BustedTruck is offline   Reply With Quote
Old 05-29-2011, 10:06 PM   #4
tk-mpl
tk-mpl's Avatar
It. Is out of a 2007 tahoe RPO LMG.
