Old 05-29-2011, 07:17 PM   #1
northern 85
northern 85's Avatar
!965 Panel rear spring Question?
Looking to lower the rear of a 65 short panel aprox 4 inches with drop springs, im thinking they would be different than the trucks due to the weight of the panel.Any info?
northern 85 is offline   Reply With Quote
Old 05-31-2011, 07:08 PM   #2
northern 85
Re: !965 Panel rear spring Question?
Any suggestions?
Old 05-31-2011, 09:44 PM   #3
bama63
bama63's Avatar
not sure but early classics sells heavy duty drop coils
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 06-01-2011, 05:12 PM   #4
kieth
kieth's Avatar
If it is a leaf spring, simply move them to the underside of the rearend......
kieth is offline   Reply With Quote
Old 06-12-2011, 08:40 AM   #5
northern 85
Coil springs on the rear.
Old 06-12-2011, 11:27 AM   #6
protrash64
Resistance is Futile
protrash64's Avatar
I used 4'' HD springs from CPP on my 'burb. They now reside under the '66 LB.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-12-2011, 12:04 PM   #7
kieth
kieth's Avatar
I used 8" air bags to replace the coil springs on my 66 gmc SWB
