Engine covers 5.3
I was wondering if any of you have custom engine covers on your 5.3? I can't stand the way the stock one's look and without one is ugly too. Does anyone sell one or do any of you make one? Thanks.
![]() Join Date: Dec 2007
Re: Engine covers 5.3
Its tough with the tall truck plenum. I like the Vortec MAX 3 piece cover......
I plan to modify a 2010 Camaro SS cover, however with a ls6 intake..... |
meowMEOWmeowMEOW
No one sells custom ones for the trucks (that I could find), but there are a few styles. Theres the Vortec Max and Vortec 6000 covers, the single peice 5.3 cover, the escalade style cover, and the old squareish style cover. There is a member on here who did a custom molded one from a 3 piece cover and it was pretty slick.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#4 | |
Charlie Daniels w/ a Tq Wrench
They are all interchangeable although some of them require a little trimming if you have the DBW throttle body. Here was a custom one I saw at the Auto Fair, not my favorite design but it was definitely smooth. Looks like he took one of the rounded ones, shaved it, then added wings. ![]() Or you can do things to clean up the stock ones, this my one day transformation on my 01, a little filler primer, colormatched paint, and a silver paint pen went a long way. I was rushed, so I am going to redo it soon and smooth the spots where the labels used to be on the radiator cover, chrome coil covers and do a few other things. ![]()
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s Last edited by GCncsuHD; 06-07-2011 at 10:34 AM. |
page 99 has one that look decent
http://www.hotrodlane.cc/2010%20PDF%...g2010main.html |
holy crap my heart just stopped for that price...............wow.......i think ill try and build one lol!!!
Made this one, but not using it...
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
Bump
http://i1103.photobucket.com/albums/...e1993/nn-2.jpg |
Old member
I sure would like a custom cover for mine. If I ever get the time I will build one I guess.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Here is what I have, Made by BH Custom designs for my truck intake. I don't have it painted or on the engine yet but it does fit.
I just don't get covering up a motor.
On that note: NSFW https://www.youtube.com/watch?v=tieA5wfcgH4 Last edited by littlevictories; 07-31-2014 at 11:35 AM. Reason: added NSFW tag |
Mine from BH. And modified for oil filler access. Looks like the front is a little different. Did you get coil covers as well?
#13 |
Stock cover smoothed and vortec badge removed. Then painted body color. Something a little different but still somewhat stock looking
#14 |
Before paint
#15 | |
#16 | |
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
#17 |
Bdub?
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
#18 |
Well, got mine painted this weekend with VHT wrinkle paint. I should have done some body work on it but I don't know how so here she is.
#19 |
Old member
That looks pretty darn Cool.
#20 |
#21 | |
(lol) I remember when we designed those for the GMT800 program. It was sort of our first foray into 'underhood aesthetics'. Total shock for me as a chassis/powertrain guy. I designed the air cleaner to match the engine cover but the ribs were "insies". By the time I was done with the design "insies" were out and "outsies" were in. We ended up with the squarish cover you referenced and the airbox that is still in use (for the foreseeable future). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#22 |
OKGMC4, do you know what kind of bolts are needed to hold the cover in place? I took the cover bolt off the intake and took it to the store and found it fit bolt size M6-1.0 When I tried to screw that size bolt into place it only screwed in a few mm and then I couldn't screw it in any more (with hands only, I didn't want to strip anything).
Anyone have any ideas as to the size bolt I need? |
#23 | |
Registered Cruiser
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
#24 |
Old member
Went the other day to the local sheet metal place and had them make me a shroud for the radiator to put the twin fans on. I went to pick it up this morning and I asked if he could make me a cover for the intake. He took some measurements and went back inside and did a quick version of it out of galvanized sheet metal to get some idea of how to bend it. He is going to make it out of aluminum and then I can form it and after we get all the bends and cuts made he said they will weld a front piece on it to give it strength. He said it would be next week before he could do it which is fine.
#25 |
I did use a slightly shorter bolt, and a couple washers underneath as shims for height adjustment to my coil covers. Also, went with round, allen head, stainless bolts because they is shiny. : ) Got them at Ace Hardware.
