Complete 71 chevy wire harness
Have a very nice original 71 chevy wire harness. No wires have been cut harness is the nicest original I have seen. Includes Fuse box, all interior wiring, all underhood wiring, and wiring all the way back to the taillights, including all plugs. I can post up pics.
$250 shipped.
71GMC 4X4 6.0 LQ4 NV4500/205 Dana 60 with crossover steering and a 14B in the rear, 69 longbed 4x4 with a cummins and D60 frt and D80 rear. |
![]() Join Date: Jan 2007
Re: Complete 71 chevy wire harness
interested can you post some pics thanks
[img]img_0524.jpg[/img]
? not sure on this pic
So after a close inspection last night here are the details I noticed. The harness breaks down into, Interior with fuse box, front headlight etc., engine harness, harness that goes from firewall to back of truck frame, rear tail light etc harness.
The interior harness is near perfect no cut wires plugs for everything including the entire dome light harness and even the cigarette lighter. Headlight harness is very nice as well only wire that has the end missing is the big red wire that hooked to the junction box by the battery. I believe this was a ring terminal would be easy to replace. Engine harness is missing the ends off of the heavy purple wire that went to the starter and the light yellow wire that also went to the starter. It is also missing the end off the temp sender wire. All these wires are full length with just the terminal or part of the terminal missing. The four stranded wire that goes from the firewall to the back of frame has both plugs on the ends and has not been cut but someone did piggyback wires to it for a trailer plug. The rear harness is in great shape has all the ends and plugs including the ground terminals. I haven't cleaned it up at all it is just like it was when I pulled it from the truck. This was a long bed 3/4 ton with a v8.
#13 |
still available if anyone is interested??
#14 |
I would be interested at a lower price , and i need to check to see if it would work on a 72 . is it an air truck or does it matter im not sure of that either . im checking
#15 |
![]() Join Date: Apr 2011
I need the interior harness with the fuse block if it is for an AC truck
Posted via Mobile Device |
#16 |
This was a factory air truck. Feel free to PM me offers.
#17 |
Sent you a PM
#18 |
I read the harness from the cab to tail has been opened up and so how much for the cab to T/L harness and the T/L harness ? if you still have ,thanks shipping to N0B-2K0
#19 |
interior harness is sold. The rest is also sold pending payment.
#20 |
interior harness recieved, very nice thanks Tim
#21 |
Harness is sold to Timbo1 and jimer1964 thanks guys.
