Old 06-15-2011, 09:16 AM   #1
Low87
been here longer than Liz
Low87's Avatar
why am I stinky?
Run with it.
Exhaust on the K5 reeks, closest I can compare it to is a firecracker or almost gunpowder. Since I haven't fixed the AC yet, I roll with the back window down, meaning by the end of the day I smell like it too.
I plan on rebuilding the TBI and giving it a tune up, think any of this will help? Gotta find out what it is.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 06-15-2011, 09:29 AM   #2
Jonboy
Slots go on anything!
Re: why am I stinky?
Hey Stinky, some of your problem is driving with the back window down. It creates low pressure, and sucks the exhaust fumes in the cab. While you may have a small problem with the combustion, it's the fact it is getting sucked inside that is killing you (or at least making you stink). My '77 was horrible about this; it would make you smell like you took a bath in gas.
1974 Jimmy- 5.3/4L80e/NP241
Old 06-15-2011, 10:31 AM   #3
Low87
Low87's Avatar
Bummer, I like that back glass down.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 06-15-2011, 10:43 AM   #4
notyo_cheez
Cool Re: why am I stinky?
Running rich, or you need tail pipe extensions, or both? Had that issue with a '69 Skylark I used to own, the fumes were killing me until I extended the tail pipe another 6". The rust holes in the trunk floor and back window didn't help especially after I removed the severely weatherbeaten package tray...
notyo_cheez is offline   Reply With Quote
Old 06-15-2011, 10:49 AM   #5
Low87
Low87's Avatar
Notyo, when I bought the K5 the exhaust was cut right behind the cat. Nearly passed out making the 2 hour drive home. First thing I did was put on a muffler and route the exhaust back to the rear corner. Pretty sure it's good now.
I'm not sure about rich, it's got a rough idle like it's lean, or a vacuum problem I haven't found yet.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 06-15-2011, 11:37 AM   #6
notyo_cheez
Just guessed sight unseen and based on personal experience. Vacuum leaks need to be fixed of course, could be everything or nothing.
Old 06-15-2011, 11:48 AM   #7
Low87
Low87's Avatar
My EGR has two ports coming off of it, but only one hose. Which one do I use?
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 06-15-2011, 12:41 PM   #8
notyo_cheez
Not absolutely sure, vacuum opens the valve during warm-up and will close when the engine is at operating temperature. They should connect to a switched port somewhere, not very familiar with TBI systems.
Old 06-17-2011, 09:54 AM   #9
bmchevy1979
bmchevy1979's Avatar
It could be your cat my k5 would do the same thing and when I took the cat off it was a whole lot better and the fact that it dumped a pound or two of soot when I turned the cat on its end. I am pretty sure the repair manual even says that a strong smell is an indicator of a cat going out but you will have to check on that one as I don't have my book around right know. But my blazer was also in bad need of a rebuild
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 06-17-2011, 11:22 AM   #10
notyo_cheez
If the engine runs rich the pellets will melt in the cat and eventually clog it. If your area requires annual emission testing it will get flagged if CO levels are too high. Worth a look, and of course you'll need to correct the rich burn before replacing the cat. Several counties in TX require emissions tests for all vehicles 2-24 years old, mine doesn't.
Just a thought.
Old 06-17-2011, 11:51 AM   #11
Papa-J
Papa-J's Avatar
Stinky like i fired of shotgun shell = Blown or bad Cat
I've had this on a few vehicles.
1968 Chevrolet C10 - Needs lots of love
1996 Chevrolet S10
Born and raised on the east coast
Papa-J is offline   Reply With Quote
Old 06-17-2011, 03:16 PM   #12
Low87
Low87's Avatar
Good idea guys. Wish I'd have checked on this prior to have the exhaust done (PO cut if off just after the cat, I added the muffler and routed the tip out).
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
